I drive a 98 F150 and my check engine light just came on. I have found no obvious problems, is there any kind of test i can do to find out what caused it to come on without taking it to a repair shop?
There is a tube that picks up changes in the gsa fumes at the fill tube, that are sent to a sensor on the firewall, part of the emission control system, this will set off the check engine light.
There are dozens of things that can cause a CEL.
Guessing at the cause without any codes is about like pi$$ing into the wind.
