Ford Racing 302 into my Mazda B2300 - Ford Truck Enthusiasts Forums
Old 02-19-2006, 07:39 PM
juanone's Avatar
juanone juanone is offline
juanone is starting off with a positive reputation.
I am in the process of installing a new Ford Racing 302 short block, Edelbrock Performer RPM heads, Ford Roller E303 Cam, RPM Intake, MSD Ignition, AOD Automatic, Dual exhaust out in front orf right rear tire.
I will post pictures once I know how.
Old 07-18-2014, 05:18 AM
1949f1's Avatar
1949f1 1949f1 is offline
1949f1 is gaining momentum as a positive member of FTE.1949f1 is gaining momentum as a positive member of FTE.
post some photos. i have a 2001 b2300 that i am thinking about doing a 302 also. not much info on doing one in a mazda. i know it is the same as a ranger. what mounts and oil pan are you useing and also do you have ac and plan on keeping it hooked up.
Old 07-18-2014, 09:08 AM
juanone's Avatar
My B2300
Hey man, I just sold my B2300 but here are some photos that may help you. I took the ac off, it has a Centerforce clutch, an 8.8 rear from an SVT Mustang, Tremec TKO2 5 speed transmission, stainless steel driveshaft, MSD Ignition, March Pulleys, New Camaro Z28 Radiator, etc...oh and the digital gauges are rocking awesome.
Good luck
Old 07-24-2014, 04:09 PM
badranger34's Avatar
badranger34 badranger34 is offline
badranger34 is starting off with a positive reputation.
Wow, that modified fan blower box is legit.
Any details on it?
Old 07-24-2014, 05:36 PM
juanone's Avatar
Heater box
Handmade, welded aluminum and polished. Way too much time and money if you ask me.
Sure looks nice.
Old 07-25-2014, 04:21 AM
1949f1's Avatar
GREAT job. very clean work. i went with a reman 2.3 and going to sell it to a man at work for a good return on what i have in it.
Old 07-25-2014, 06:52 AM
juanone's Avatar
Sold it
I sold it to a great friend. I regret it every day. This was like an SVT Mustang in Sheeps clothing.
Had it chassis dynoed, turned 300 hp at the rear wheels. Truly sweet machine.
Old 08-17-2014, 11:56 AM
NoBowTiesHere NoBowTiesHere is offline
NoBowTiesHere is starting off with a positive reputation.
nice Project !
4100 rpm miss brehenkel 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 23 03-16-2016 04:13 PM
4100 rpm miss brehenkel Performance & General Engine Building 2 02-14-2016 09:18 AM
Low RPM misfire. HELP!! x79f100x 1973 - 1979 F-100 & Larger F-Series Trucks 4 01-05-2010 01:52 PM
MSD ready to run dizzy instalation?? Colo79Ford 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 12 04-06-2006 06:19 PM
stumble and miss after msd ignition install Big Daddy J 1978 - 1996 Big Bronco 19 09-26-2005 03:43 PM
Tags
2300, 302, b2300, cyl, edelbrock, engine, ford, mazada, mazda, msd, putting, racing, swap, truck, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
