Pellet Stove problem/question
1 year ago I was given an old (15yrs) Whitfield pellet stove with no manual to read and the old owner moved out of state. It seems that at night and sometimes during the day the burn pot will not release the ash through the bottom of the grate. If this happens the pellets will not burn correct and they build up (Call Clinkers?) and overflow in the burn pot. The heat then will be warm and not hot and the stove will shut down.
This is what I have done so far: New gastket around the door (helped some). Changed outside flue lenghts (Note the flue is located between our house and our nieghbor house onlt about two foot away) (No help). Tried different brands of wood pellets (No help). Any ideas what the problem is? I live in an old drafty house, in such, that I was told that I do not need to connect up the cold air intake in the back of the stove. Also the stove itself seems to be working okay as far as the dampener. The pellet feed is adjustable and seem to work. BTW I always need to run the stove mostly with the dampener open all the way up and the pellet feed on minimum ( drops pellets once every 10 seconds or so). If anyone know any about these stoves pls help, it a pain to get up at night and force the ash down through the grate.
Wow, I thought I was the only one on the planet with a pellet stove. Nice to know there are others. I love mine. Only problem is there are only 2 places on Long Island that sell pellets. $8 and $9 per 40 lb bag! Anyway, Hadaford, hope these will help;
http://hearth.com/what/specific.html
http://www.butkus.org/whitfield_pellet_stove.htm
http://www.lennoxhearthproducts.com/
Got it working right!!!!! Yea!!!! With no manual, I found out there are slides on each side of the burn pot. Found out that: 1) They are clean out slides and 2) They are suppose to be closed not open. The problem with the slides being open was that there was poor air flow up through the burn pot. Now with the slides closed, it is putting out HOT air and sounds like a jet engine with the dampiner turn open past half way. Thanks guys for all your help!!!! My wife was about to throw it out.. ;-)
Originally Posted by Hillbillywagon
I pay four bucks a bag for the wood pellets (buy them by the pallet 40lb bags) and about 7.50 per hundred weight for the corn (delivered in bulk). If you can do it that way the corn is not only much cleaner burning but puts out more heat per pound and is cheaper per pound to boot. You still need to have some pellets on hand to start it if it goes out however.
I wouldn't mind using corn, but I was told that older Whitfield stoves like mine would jam up the auger. Oh well, the stove is now working like it should.
Nitramjr
12-05-2013 10:57 AM
jsutton
19
08-03-2011 11:33 PM
four-sixty-power
11-14-2005 02:45 AM
