Bad/Old Gasoline - Ford Truck Enthusiasts Forums
General Automotive Discussion
Bad/Old Gasoline
Old 02-19-2006, 03:23 AM
Caplax40 Caplax40 is offline
Caplax40 is starting off with a positive reputation.
Bad/Old Gasoline
For fuel injected vehicels, what does old/bad gas DO to a car exactly? What are the physical symptoms of having bad/old gas? And if there's any damage done, what can be done to repair it?
I'm working on a car that has been running sporadically on and off again for the past few months and is still using the same tank of gas (aside from two gallons of new fuel being added about a month ago). Would adding fuel stabilizer work or is it better just to drain the tank and refill with new gas? And, what's the proper way to get that gasoline out of a tank anyways?
Sorry if this isn't making a whole lot of sense, I'm writing this at 1:20AM after working on said car for several hours!
Old 02-19-2006, 09:25 AM
94van 94van is offline
94van is starting off with a positive reputation.
My '89 Mustang sits a lot, in the past 2 years, it's been driven 650 miles. Some of that gas is probably 2 years old.
Now, it has a sealed system, and is garaged, so it doesn't go thru extreme temperature changes. I use no additives. It starts and runs fine.
Old 02-19-2006, 10:09 AM
cjben cjben is offline
cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.
how much gas is left in the tank? I would just try to run it until it is empty,then change the fuel filter,and fill it with fresh gas,at least that way if it still runs bad,you know it wasn't a bad fuel problem.
Old 02-19-2006, 12:49 PM
Kruse Kruse is offline
Kruse is gaining momentum as a positive member of FTE.
Quote:
I think this is one of those "it depends" type of answers. It probably depends on how old the gas is amoung other variables.
A couple of years ago I wanted to mow some grass with a push mower. I ran out of gas in the mower and had none in the spare can. I then siphoned some out of a vehicle that had been sitting for about two years. The mower ran okay, but the grass wasn't too tall so the mower wasn't worked that hard. Anyway, when it came time to shut the mower off, it would not shut off! It continued to run despite not having any ignition to fire it. I then realized that it was running on bad gas. Not sure if I did any damage to the mower, but I'm sure it didn't help it any. It continues to be a good mower and I use it still....
Old 02-19-2006, 01:47 PM
Putt's Avatar
Putt Putt is offline
Putt is gaining momentum as a positive member of FTE.
Sea Foam Motor Tune-up from NAPA, CarQuest, Schucks,Checker, Kragen etc. will make the fuel burn acceptably and prevent further problems. It is a fuel stabilizer for up to 2 years.
Old 02-19-2006, 05:40 PM
jim henderson jim henderson is offline
jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.
Bad Gas has a characteristic smell, not sure how to describe it but once you smell it you know. It doesn't smell sharp like fresh gas, it smells kind of funky and not as harsh to the nose.
I had a car that sat for about 6 years and one day I decided to drain the tank and burn it in my daily driver. Big mistake.
The gas had a lot of sludge, as I discovered later, stupid me thought filtering thru some clean rags would do the trick. This sludge clogged up the fuel filter which caused my car to starve for gas.
The symptom on that car was that the car barely had enough power to get up to freeway speed. It ran smooth but had no power. If you floored it, it would go to high RPM but not make any power. At first I thought the tranny was slipping. Eventually I figured out that the computer was downshifting to compensate, thus the high RPMs, but there was still not enough power for me to feel the downshifts.
I changed the filter, ran some Techron and several tankfulls thru the car and it was fine.
The fuel stabilizers may be worthwhile, but I never tried them for longer than the winter season in the lawn equipment gas cans.
Good Luck,
Jim Henderson
Old 02-20-2006, 12:12 PM
Bart99GT Bart99GT is offline
Bart99GT is starting off with a positive reputation.
Gasoline leaves a varnish behind with age. The biggest problem with FI engines is that if there's enough fuel left in the injectors over time, the varnish could clog the injectors. Fuel stabilizers help prevent fuel varnish by keeping the chemicals in suspension in the liquid fuel.
Old 02-20-2006, 09:10 PM
Is there any way to get the gas out of there without removing the tank?
The car has an access hatch underneath the rear seats that allows a person to replace the fuel pump without dropping the fuel tank so I guess I'll just siphon it out from there?
Old 02-22-2006, 05:14 PM
Nathane Nathane is offline
Nathane is starting off with a positive reputation.
start it up, and go for a drive?
you could also disconnect the fuel lines at the tank.
Good luck
~Nate
Old 02-22-2006, 09:19 PM
Good luck
~Nate
Car won't stay started longer than a few minutes or else I would just go drive it all off. That's another issue in itself.
Old 02-22-2006, 10:05 PM
JD717 JD717 is offline
JD717 is starting off with a positive reputation.
Disconnect the fuel line at the filter, and set up a power source to power the fuel pump in the tank, it should work to drain the fuel.
Old 02-22-2006, 10:31 PM
Quote:
If it's disconnected at the filter will it just flow freely out till it's all drained with the key in the accessory position?
Old 02-22-2006, 11:41 PM
Bdox's Avatar
Bdox Bdox is offline
Iconoclast
Bdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputationBdox has a superb reputation
It's gotta be in the on position.
Old 02-24-2006, 09:38 AM
TexasGuy001 TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
For that to work you would have to keep cycling the key on and off. The pump wont stay running. It only runs for a second or so when the key is turned on to prime the engine before it starts.
Propane Conversion on my Edge - 6 month report PaulsEdge Alternative Fuels, Hybrids & Mileage 7 01-09-2017 08:09 AM
Ford van Econoline E series CNG all parts free swap for gasoline parts, (Expedition, F150?) GreenMM Ford Truck Parts for Sale 13 01-07-2017 09:49 AM
Emergency! Gasoline in the my diesel fuel... F357 6.0L Power Stroke Diesel 48 02-22-2015 04:08 AM
stale gasoline questions dentvet General Automotive Discussion 2 01-15-2007 06:17 PM
Acetone to boost MPG? ItsReallyDarren General Automotive Discussion 6 07-19-2004 09:30 PM
Tags
bad, car, damage, fuel, gas, gasoline, pictures, problems, running, symptoms, system, systoms, tank, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
