bent rod 5.4 2003
Old 02-18-2006, 12:44 PM
fuss's Avatar
fuss
fuss is offline
bent rod 5.4 2003
truck was wrecked on its side oil in cylinder oil does not compress result bent rod i know motor has to come out but from looking at the bent rod with the pan off there are cap bolts but no cap looks to be one piece what are these motors throw aways so you buy short block
Old 02-18-2006, 12:54 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
No, they are probably a cracked cap design which means that the rods are mede, then cracked at the crank journal so that when bolted back together, they fit perfect.
Old 02-18-2006, 10:24 PM
Silver00f150's Avatar
Silver00f150
Silver00f150 is offline
Yes they are a powdered metal rod that is cast as once piece and cracked. The resulting break fits together perfectly. I have heard these rods give way before the crank. I would just have the crank journals polished and install all new rod bearings, obvioulsy replace the bad rods and have the others crack checked as well as the crank magnafluxed and checked.
Tinytune812
29
02-22-2017 04:25 PM
doug42190
06-10-2016 10:25 AM
Lilbrowntruck
04-14-2016 10:10 AM
adamtheman16
08-06-2010 06:14 PM
Kongslibakken
11-23-2006 12:08 AM
Quick Reply: bent rod 5.4 2003
