460 engine build
460 engine build
i have a 77.5 f-250 crewcab 4x4 i am going to put a 460 engine and a 4 spd trans with 4.10 gears a am going to put 38 inch tires on my truck so for road speed 65 mph it would rev 2300 rpm so i would need low end torque and still have fairly good mpg and not spending my savings on just the engine. i want to keep the stock botom end and heads maybe a three way cut, leaving the cam i have seen ppl talking comp cam xtreame 4x4, timing set (advanced, strait up, or retarted) and intake, carb and valve train. what componets would work the best for this setup.
Start off with the timing chain swap (to a pre-'71 spec unit) and add some headers. This will give you noticeable power gains without sapping your wallet. Then you can decide if you want to move into intakes, heads, cams, and the like.
And take a little time to explore here for some basics - https://www.ford-trucks.com/forums/s...d.php?t=269758
Brad
Brad
77Fordf100
03-02-2006 06:21 AM
terrapin88
25
02-15-2006 06:08 PM
akfj62
10-23-2005 09:47 AM
