460 engine build - Ford Truck Enthusiasts Forums
460 engine build
Old 02-17-2006, 08:58 PM
theguy_88 theguy_88 is offline
theguy_88 is starting off with a positive reputation.
Question 460 engine build
i have a 77.5 f-250 crewcab 4x4 i am going to put a 460 engine and a 4 spd trans with 4.10 gears a am going to put 38 inch tires on my truck so for road speed 65 mph it would rev 2300 rpm so i would need low end torque and still have fairly good mpg and not spending my savings on just the engine. i want to keep the stock botom end and heads maybe a three way cut, leaving the cam i have seen ppl talking comp cam xtreame 4x4, timing set (advanced, strait up, or retarted) and intake, carb and valve train. what componets would work the best for this setup.
Old 02-17-2006, 09:20 PM
76 F-150 390FE's Avatar
76 F-150 390FE 76 F-150 390FE is offline
76 F-150 390FE is starting off with a positive reputation.
you might want to try posting this in the 460 fourm (385 series fourm) the people there can tell you what you need to know.
Old 02-17-2006, 09:22 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
Head's up !
The engine forums are the best place to ask Specific Engine question
Basically you are looking for Low end torque.
Low end torque is better achieved with a 2v carb as opposed to a 4v.
Install a 68-72 429 Timing chain and gears.
Old 02-17-2006, 09:23 PM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
Moved...........
Old 02-18-2006, 11:08 AM
Brad Johnson Brad Johnson is offline
Brad Johnson is starting off with a positive reputation.
Start off with the timing chain swap (to a pre-'71 spec unit) and add some headers. This will give you noticeable power gains without sapping your wallet. Then you can decide if you want to move into intakes, heads, cams, and the like.
And take a little time to explore here for some basics - http://www.ford-trucks.com/forums/sh...d.php?t=269758
Brad
Old 02-18-2006, 03:19 PM
what type of cam, intake, and carb would be the best to run?
Clicking Noise From Hub Area adam42481 1999 to 2016 Super Duty 7 03-13-2006 01:10 PM
Ford axle code 47 ? 77Fordf100 Clutch, Transmission, Differential, Axle & Transfer Case 1 03-02-2006 06:21 AM
95 F150 Front end hart2345 1987 - 1996 F150 & Larger F-Series Trucks 1 02-15-2006 12:25 PM
1998 Ranger 3.0 to 4.0 engine swap. Easy?? Brilac Ranger & B-Series 5 12-22-2005 10:28 PM
HELP! Bought lift might not have all parts bsmotorsports Offroad & 4x4 6 11-28-2005 03:55 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
