1990 460 Truck Specs - Ford Truck Enthusiasts Forums
Old 02-16-2006, 11:44 PM
Boont Boont is offline
Boont is starting off with a positive reputation.
Can't seem to find the code list for my truck. HB 55, Type GVM X259, Body FKM, Trans E, Axle 39, Tape 2, Springs HA
1990 F250/7.5, Long Bed, 2WD, Super Cab XLT
Is there a web site? I saw this somewhere before but can't seem to find it now.
Has overdrive button so does that make it a five speed? What rear end ratio?
thanks, b.
Old 02-17-2006, 07:18 AM
85lebaront2's Avatar
85lebaront2 85lebaront2 is offline
Old School Hot Rodder
85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold
Trans E is E4OD, four speed automatic Overdrive. According to the owners manual on the 1990 F250 I bought for parts, 39 axle is a 6250 lb capacity Ford 10.25" 3.55 ratio open rear end. The parts truck has a C9 code axle for probably the same capacity, but limited slip. The tag on the axle says 3L55. If you need an owners manual, this one is going to be available.
1990 f150 bullbar/pushbar/grille guard? 1990frd150 1987 - 1996 F150 & Larger F-Series Trucks 1 01-07-2015 08:07 PM
1990 f250 2w drive lift kit, cant find one help!!!! yamaha4400 Brakes, Steering, Suspension, Tires, & Wheels 7 10-27-2014 05:20 PM
slow crank 1990-f250 1987 - 1996 F150 & Larger F-Series Trucks 2 06-25-2014 11:32 AM
Door Tag Decoder csurp 1987 - 1996 F150 & Larger F-Series Trucks 22 01-31-2014 11:08 PM
CD Service Manual for 90 Diesel F350 1990DieselQuadDually Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 1 02-01-2012 10:11 PM
Tags
1990, 460, f250, ford, specs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
