Press and HOLD the Valet/Program button until you hear the horn honk twice. You will here it honk once for menu 1 then continue to hold it till you here it honk twice for menu 2. Once you are there release the button.
Within 10 seconds press the Valet/Program button three times to select option 3.
Press your lock or unlock button to select the option you want for run-time. There are three levels. The number of flashes on your LED will show what level has been chosen. 1-flash 12 minutes, 2-flash 24 minutes, 3-flash 60 minutes.
Turn the key on then off and you should hear a long tone as you exit programming.
