head swap/spacer q's again
Tried a search, probably didn't do it right, sorry if this has been covered a hundred times.
When swapping 351c heads to a 351m/400 you have to use spacers to make up the difference in deck height to use a 351c intake right?
But if you want to run 351c heads on a 351m/400 and use a 351m/400 intake manifold you don't need to use the plate right?
If you plan on using 351C 2V heads ,they are the same asthose on the 351M/400. If you're using the 351C 4V heads,you need the spacers and valley pan cover .You can't use a 351M/400 intake with 4V heads because the ports are much larger on the 4V heads,if you go this route you must also use a Cleveland intake....FF59
79-F350
05-03-2014 12:23 PM
ErrorS
01-15-2008 12:57 PM
cruz76
03-24-2006 09:14 PM
tastyklair
07-28-2004 12:46 PM
