how much for a stock 9"? bolt-in for 54?
Per the technical article on rear-end swaps for my 54, I'm looking for a 9" which is claimed to be a bolt in. [Someone please confirm!]
The local yard quoted me $400 for a stock 57-72 9", hub to hub. Seems excessive - am I just dreaming? I was thinking more like half this amount.
Thanks!
Thanks!
Brad -
I agree with you on the price range. Make them a counteroffer of $200. Start checking classifieds, ebay, local pennysaver papers, etc.
Be advised that the difference between early and later 9" assemblies is bearing sizes and whether the E-brake is self-adjusting. You'll want the later (self-adjusting) model if you get a choice. I think it was '66 or '67 when they went that way.
Also, pay attention to the gear ratio. A good road gear is 3.00:1 (or something between 2.75 and 3.25). You won't be happy if you wind up with a 4.56 or something. There is a tag on the pumpkin that telss what the ratio is.
Ford 9" are in high demand by the drag/circle track racers and hot rodders since they are so strong, so some think they are gold plated. There are some bolt in 8" units that are still plenty strong for anything short of a Banzi dragracer with >400HP that sell for a lot less and are easier to find.
Tell us where you're at. I'm sure someone here could help you find a good one, maybe even one with a nice ratio, for way less money.
I would say it is very unlikely though that you would find one that wouldn't require relocating and welding the spring perches and/or the shock mounts.
Good luck.
Good luck.
I'm in Portland Or. We have a big swap meet here the 1st week in April. I'll keep checking the ads, Craigs list, etc. between now and then. But I'm also having my 3rd child on March 31st, which means I probably won't have a ton of time this spring/summer to deal with much rear-end changing except for diapers!
If you have no other option ask the yard to include the shock crossmember and spring mounts in the deal for $400. Then it would just be a matter of bolting in the rear end and locating the correct placement for the crossmember and bolting that in too.
