Electronic Valve Cover Gaskets... HELP!
Old 02-14-2006, 06:25 AM
Diggerz_44's Avatar
Diggerz_44
Diggerz_44 is offline
Unhappy Electronic Valve Cover Gaskets... HELP!
I'm kind of new to the repairs of 7.3's. When our company had Chevy trucks, I got quite a bit of diesel repair practice, but now that we have all Fords in our fleet..... repairs are almost non existent!!! I do recall having to have a valve cover gasket replaced because it shorted out to the head. The same truck is now having the same problem again (2 years later). I just need to know if the valve covers can be removed WITHOUT damaging the electronic gaskets for inspection!? The truck is turning over like mad, sounds like it wants to fire but it wont. I already checked for water in the fuel and put in a new fuel filter and it's still doing the same thing. Any ideas???
Old 02-14-2006, 06:51 AM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old 02-14-2006, 07:07 AM
mech2161's Avatar
mech2161
mech2161 is offline
Yes they are reuseable. Check around the push rods for clearance.
Old 02-14-2006, 07:19 AM
Diggerz_44's Avatar
Diggerz_44
Nice truck Mech2161. Thanks for the info. Just curious..... what's your best pull? (distance/weight)
Old 02-14-2006, 07:37 AM
Kwikkordead's Avatar
Kwikkordead
Kwikkordead is offline
My truck melted the conductor in the valve cover gasket, requireing replacement of th wiring harness, valve cover gasket, and repairing the outside plug. The cause was the glow plug wires were routed right next to the push rod and rubbed through the insulation on the wire and shorted to ground.
Now on to your no start. Have you tried jumping the glow plug relay?
Old 02-14-2006, 01:23 PM
mech2161's Avatar
mech2161
mech2161 is offline
Full Pull 300ft don't know the weight.
JessieDM
17
02-09-2015 07:52 PM
79f-250custom
35
07-05-2007 10:37 AM
4speedvan
05-04-2005 12:37 PM
youthprof
09-30-2004 07:20 PM
Martys82
04-06-2003 01:55 AM
Quick Reply: Electronic Valve Cover Gaskets... HELP!
