Best way to lift 93 F150??
I have just recently purchased a 1993 F150 short bed standard cab 4x4 with 300 6 cylinder. Now i am thinking about getting a lift kit for it, i cant afford to spend alot of money on a suspension lift. I not going to be doing much 4 wheeling if any and if i do it will be very lite to mild, no extremes. This truck is also my daily driver so i still need it to be good on the street without affecting any drivability. I love the way they look with a 2 to 3 inch lift. I have heard that using blocks to raise the body gets into alot of other modifications, is there any other way to lift my truck other than suspension lift or body blocks thats not a half *** way to lift? Thanks alot!!
to do it the safe way you will prolly want to get a kit. the skyjacker kit is superior to any other kit ( i have run many different brands) unless you have a solid axle up front, which i am assuming you dont have.
you can shackle flip the rear which will net you about 3" but then you wont be able to haul quite as heavy of a load.
look to spend about $6-700 to do everything right and to allow for error (you always get nickle and dimed to death)
-cutts-
-cutts-
i think so, here the link to a kit i found:
http://cgi.ebay.com/ebaymotors/1982-...QQcmdZViewItem
Also, what all is involved with this? Is there anything else that will have to be modified? Is it a good idea for a daily driver vehicle?
Thanks!
Thanks!
Someone mentioned that if i do the shackle flip that i wont be able to load much weight in the bed. Where would i get radius arm drop brackets and for how much.
Also i stumbled upon this kit on summit:
http://store.summitracing.com/defaul...t+kit&x=12&y=5
What are some opinions on this kit?
Lifting the rear is the easier and cheaper part. For a small lift (2.5") many kits use a bigger block. However, for 4" or 6", blocks are not particularly good.
Lift kits should deal with the front alignement issue, though some are better than others in that respect. I have a Tuff Country 2.5" kit with extended radius arms and I'm satisfied with them. Other kits for your truck are Rough County, Skyjacker, Procomp, BDS, and Superlift. 2.5"/3", 4" and 6" are the standard lift amounts.
Originally Posted by sc0tty8
Do any of the kits also even out the height of the truck at the same time as lifting the truck? I don't want my truck to ride with the nose down, I would like to even it out.
kenworthfan
03-25-2007 10:29 PM
bigblue
11-16-2001 02:41 AM
