4.6 Oil Pressure problem
I have a 2002 Explorer EB with a 4.6. I purchased it in August 2005 with 85000 miles on it. I am the 3rd owner.
The truck is in great shape and I love driving it. I travel a lot for my work. The on board message center said it was time for an oil change and I took it to my favorite Quick lane at a Ford dealer for the service. They found some recalls that needed to be performed, just what I wanted to find out. Now the plot thickens.
Since the weather has been cold ( 30's in the morning ) at start up my low oil pressure warning comes on and the gauge reads 0. I check the oil level and its fine, start it again and the pressure is fine for the rest of the day. The problem repeated itself on cold mornings. I checked inside the valve cover while idling at O psi and it seems wet inside, no noise at all. I changed the oil myself thinking the oil filter was pluged or bad. I used a Fram oil filter and Castrol 5W30 with one quart of Castrol sythetic to make up the recomended amount. I now know that I should have used 5W20. I cut apart the old oil filter, nothing to report there, typical findings. I still have the same problem at cold start up.
Could the 5W30 be that much thicker? Is the up take screen plugged ?Is this typical of the 4.6 ? Ive had 2 other 5.4 without any problems at all.
Thanks in advance
Caber
Thanks in advance
Caber
