Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 03-11-2007, 06:56 AM
Gunner15a Gunner15a is offline
Gunner15a is starting off with a positive reputation.
Quote:
Originally Posted by wolftan
Thanks....is the core easy to replace or time comsumming?
EVERY vehicle that I've ever had to replace the heater core in has been a NIGHTMARE. With a diesel, it's probably worse.
Put your masks on boys, it's gonna be a gunfight.
Gunner15a
After reading.........I guess not
__________________
http://www.ford-trucks.com/user_gall...id=135523&.jpg
Bone stock 06 F250 SD XLT 6.0L Diesel Extended Cab
Bone stock 03 F150 XLT Extended Cab
  #17 (permalink)
Old 03-11-2007, 08:38 AM
wilbur996 wilbur996 is offline
wilbur996 is starting off with a positive reputation.
Ok, upon further investigation, the replacement heater core has one additional row and about 5 more fins/inch. So maybe heat output about the same.
I added some tips in below to these instructions.
1. Drain the radiator; refer to «Section 303-03».
µ 2. Disconnect the heater water hoses from the heater core. For the heater hose coupling disconnect and connect procedure, refer to «Section 412-00».
Looking from under the hood, the hose on the left is tough to get apart. I had to rotate the hose to access to the pinch clip cause you just can't your fingers in between the hose and the heater box to squeeze the clips. Remove the plastic clips from the heater pipes before trying to pull the heater core out.
3. Disengage the stops and lower the glove compartment door.
I removed the glove box with the 3 screws from underneath. Took totally out of the way.
4. Remove the electronic blend door actuator and bracket assembly.
This is the vacuum actuated blend door rod actuator. Pretty easy to remove, just one screw, unplug the vacuum tubing. Tilt it toward you and unhook it.
5. Rotate the blend door actuator and bracket assembly.
6. Remove the electronic blend door actuator and bracket assembly.
This is the white box on top of the heater box. Unplug the wire connection and then gently pry up on the white box. It is held in place with plastic pins and snaps down onto the black bracket. The electronic box and bracket are two seperate pieces. Once the box is off the bracket there are 3 screws that hold the bracket to the heater box. You have to remove this bracket before attempting to remove the heater core because this bracket actually holds the heater core pipes toward the firewall. You can't get the heater core out with this bracket in place. Trust me on this one.
7. Remove the screws.
8. CAUTION:
The heater core cover must be raised vertically before removal to avoid damage to the heater core housing.
There are about 6 to 8 screws in this cover. Remove the screws and lift the cover vertically. The cover on mine had some silicone gasket maker around it. I will silicone back in.
Remove the heater core cover.
9. Raise the heater core cover.
10. Remove the heater core cover.
11. Remove the heater core.
__________________
Tim
99 F-350XL SD, CC, 4x4, LB, SRW, 6 spd, 7.3 PSD, HPX, Ford AIS w/Zoodad
99 E-350, Auto, 7.3 PSD, Bone Stock
  #18 (permalink)
Old 03-11-2007, 01:24 PM
Thumbs up
Wll everything is back together and the heat is working without smelling like antifreeze.
One thing to be aware of when taking the hoses of the the heater core. There are 2 o-rings and a plastic spacer. Be careful not to lose these or you'll have to get replacements. Which are available at the auto parts store. Even the plastic squeeze clips too. I've seen the whole quick connect assembly available too.
Anyways, make sure when you put the o-rings back you have the plastic spacer between them. o-ring - plastic spacer - o-ring. I had to look this up cause I had three o-ring and 2 spacers in my hand. One of the o-rings was still in the connector.
I'm no ball of fire when working on my truck but I would say it is a 2 to 3 hour job the first time. Second time around, maybe an hour.
__________________
Tim
  #19 (permalink)
Old 03-11-2007, 08:13 PM
F250_'s Avatar
F250_ F250_ is online now
Still learning every day!
2002 Ford F-250
F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of
Thanks for the extra notes and tips, wilbur996. I'm marking this thread for future reference, because I kow I'm going to need it soon ,myself.
__________________
http://guzzle.rbmicro.com/7pt3/Mods.html
Become a SUPPORTER!!
Tags
1999 , 2003 , 2006 , antifreeze , bad , core , coupling , f150 , f250 , f350 , ford , heater , hose , order , removal , smell
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
