Towing Limit Question
Originally Posted by PureGrunt
Hi,
I've got a 93 f-250, supercab, 7.3l N/a Diesel. I don't know what the towing limit on it is. Is there anyone that can help me.?
Thanks in advance
Thanks in advance
Originally Posted by Toyman
12K pounds is 12K pounds, wind resistence is another factor.
But the wind and road conditions aren't what we are talking about.
Toyman
Toyman
But puregrunt had a simple question "what is my truck rated at". You have gone to the extreme with real world conditions. The truck is rated at what the truck is rated at, will it tow more? Most likely. Do we know if he lives in the mountains, or going to tow there? Do we know what he is going to tow?
You can look at this 15 different ways and not the same answer, but they all could be correct (with in reason).
Toyman
Toyman
Toyman
Toyman
If you can predict what the wind and weather is going to for me when I go on vacation this year it would help out quite a bit, for figuring fuel economy.
Come on Snoman, if you can tell what the wind is going to do before you travel you need to tell the weather people because they can't get it right.
I respect and agree with alot of your posts but this is kind of rediculous, all the man wanted was a number on what the truck will do. He can figure it out from there if he is overweight or not. Or whether he has a flat bed or fifthwheel.
Toyman
Toyman
Keep in mind here that the tow ratings are not only based on gear ratio and HP, but by the vehicle brakes. If you add larger tires to your stock truck it takes longer to stop it, if you add a trailer to that it takes even longer to stop everything.
Toyman
Toyman
Jim
