Fuel Pressure Specs? - Ford Truck Enthusiasts Forums
Old 02-12-2006, 07:39 PM
X-Power X-Power is offline
X-Power is starting off with a positive reputation.
I have looked in all my manuals and cannot find the fuel pressure specs for my '98 V6 Sohc. Dealer told me anywhere from 20-60psi was within spec, kind of a broad number. Another guy told me his '99 X was 60psi at the valve and another dealer told me 30psi with out the Vacum line and 40psi with it.
I measured my pressure at the fuel rail valve @ 28psi and it went down slightly when I revved the throttle. I have 137k mi on the engine. The problem is I am running a free flow intake and exhaust and the engine does not seem to be making the power in the upper range above 3000rpm.
I am convinced it is being fuel starved. I recently had the a/f ratio's proffesionaly calibrated to go along with the mods but no real change in performance. My guess is I either need a new fuel pump or Fuel Pressure Regulator. All induction components and Ignition components are good.
Old 02-13-2006, 05:29 AM
Any help would be greatly appreciated
Fuel Pressure Help failsatheals 1997 - 2003 F150 5 06-21-2016 09:03 PM
Fuel pressure problem? cjben 1987 - 1996 F150 & Larger F-Series Trucks 6 08-30-2015 11:24 PM
Is my fuel pump going bad? JSTJ704 1987 - 1996 F150 & Larger F-Series Trucks 19 06-30-2014 06:25 AM
96 Ford F150 4.9L PSI? JSTJ704 1987 - 1996 F150 & Larger F-Series Trucks 3 06-15-2014 10:17 AM
Fuel Pressure and Manifold Vaccum Pressure Specs klhwarf 1987 - 1996 F150 & Larger F-Series Trucks 6 03-03-2001 01:33 PM
Tags
2000, 2005, 2006, 38, 94, aerostar, explorer, ford, fuel, mountaineer, pressure, specifications, specs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
