Multi-purpose Garage??
For 6 years now I've been throwing ideas around for a garage design to replace the one I lost from moving to a new house I have enough pre-fab 28' rafters to build a 28'x40'. The rafters are 6/12 pitch with a collar tie half way up( 3' up from bottom of rafter).
Some needs to meet:
1. 12'ceiling for a future lift.
2. A steel cross beam for a trolley and chain fall.
3. In floor heating.
4. Safe for welding fabrication.
5. Adequate insulation for reasonable heating.
6. One or two overhead doors in the front??
7. An upstairs for storage??
8. Of course, room for a couple FORD trucks!!
I know I might not be able to meet all these issues with one building but, maybe with some help I can get most of them. I haven't designed many garages and thought perhaps I could pick your brains and try and get it right the first time. It will be built by myself and my jerk of all trades buddies on a limited budget.
1995 F250 4X4 351-AUTO
Some needs to meet:
Floor heat is definitely the way to go. If you insulate well, you'll have a very cost efficient "shop" to heat. Our 28X40 stays warm all winter and cool all summer (in ND). If you've got the budget, make your inside walls white sheet metal to reflect light with surface mount electric to really make it airtight. Good luck, building your dream "shop" can be a lot of fun
Greywolf
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
07-11-2008 02:03 PM
rebellforever
27
11-28-2002 06:14 AM
Ken2600
Garage & Workshop
09-24-2002 09:57 PM
