Rear differential fill plug.
I have a 1984 Ford F-150 4x4 and I am having trouble removing the rear differential fill plug. The fill plug is really rusty and there is almost nothing left of the square hole in the center I tried turning it out and the 3/8 drive extention wants to slip in the hole. What would be the best way to try to remove the plug?
I'm thinking about putting a bolt in the hole of the plug and welding it to the plug. Then trying to turn the plug out with the bolt. The heat from welding it should also help break the plug loose. I know I have to watch how hot I get the differential housing because of the seals and the fluid in it, but I think this will work. What do you think?
The heat from welding it will cause the plug to enlarge, so try to keep it to a minimum. If you just tack a bar across the plug you won't have to worry about grabbing the bolt and twisting the welds off the shaft of the bolt. You want your tacks to be close to the edge to give your more torque on the plug and less force on the welds.
I have been able to get those plugs out if there is a little bit of the plug sticking out of the case. I just use a cold chisel and a hammer and whack it a couple times along the top edge of the plug, usually this is enough to break the rust free. Next time I have to take my plug out I'm going to replace it with a pipe plug with the square on the outside.
Originally Posted by Larry_the_handyman
Watch out for rocks and curbs.
ExPACamper
59
05-04-2017 09:39 AM
jjurva!
07-26-2013 01:13 AM
recluse
10-29-2011 11:02 AM
mantta
01-20-2003 04:51 PM
