Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 02-09-2006, 08:49 PM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Talking Fabman Equip Update
IT REALLY WORKS !
Just completed my first trial run with my homebuilt "hydrocyclone". Work's better than I hoped it would!
Standard practice is to let the mixed Bio stand for a min of 12 hours, this is to let the glycerol "seperate" and fall to the bottom of the tank, then decant the Bio off.
With the new hydrocyclone the seperation occured within 30min of mixing. Will check the bottom of the tank tomorrow to see if any glycerol settled out tonight.
If this work's as good as it look's, it will forever change the way bio is made by "homebrewers" Should shave alot of time of the process.
The next step is to build a "pulsed-flow-reactor". That would eliminate the need for making it in "batches" and allow a continious flow process. So little time............So many projects. FABMANDELUX
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #2 (permalink)
Old 02-10-2006, 12:03 AM
woogs's Avatar
woogs woogs is offline
Garage is empty, add now
woogs is starting off with a positive reputation.
legacylawns
how does it work? Hydrocyclone, sounds like it spins, does it spin and make the glycerin come out faster by centrifugal force?
man I wish you lived in Texas so I could check this all out.
-matt
EDIT: Don't blame me if Centifugal (sentrifical) is misspelled. My mom told me how to spell it, she's just a school teacher.
__________________
You can run but you'll just die tired
  #3 (permalink)
Old 02-10-2006, 06:21 AM
1935 Ford pickup
-matt
Check out : http://www.odisfiltering.com/phydro.html for a better idea. FABMANDELUX
__________________
  #4 (permalink)
Old 02-10-2006, 08:15 PM
1935 Ford pickup
Day 2
After settling overnight I found about 70 percent seperation. Acted like it didn't have enough flow. Did a flow test on the pump I used today and found 8.5 gal/min. Way to low, the size of hydrocyclone I built requires a MIN of 15 gal/min and a max of 35 gal/min. Not enough velocity! Will try and find another pump this week and try again, BUT.......It looks like this just might work! If I can get 70 percent seperation in 30 min with a unit that pump's less than the minimum GPM I think I can get complete seperation with more velocity. Wish me luck! Will keep all informed. FABMANDELUX.
__________________
  #5 (permalink)
Old 02-11-2006, 05:32 AM
leskwvo leskwvo is offline
leskwvo is starting off with a positive reputation.
Good luck.
I hope yours are smaller then what we saw in the link. That stuff was hardly garage type equipment.
  #6 (permalink)
Old 02-11-2006, 12:15 PM
monsterbaby's Avatar
monsterbaby monsterbaby is offline
1967 Ford Galaxie
monsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputation
Ok I have a question on this, are you still having to use methyloxide? I was reading somewhere and now I can't find it that someone had developed a process to seperate the glycerin out of the oil without the chemicals I do believe it was using a centrifuge but like I said I haven't been able to find that since the first time I looked at it, and that would make it even better if all you had to do was run it through a process without having to buy lye, or methynol, and would greatly reduce the costs associated with making WVO into biodiesel, plus no dangerous chemicals to play with. Plus you wouldn't have the washing and drying to worry about doing I would think.
__________________
Rob
Learn from your parents mistakes.......... Use birth control
  #7 (permalink)
Old 02-11-2006, 10:28 PM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
Quote:
Glycerin is is part of the vegetable oil molecule. The Methoxide replaces it with a Methyl radical freeing the glycerol, this is a chemical reaction and cannot be brought about by physical force ie a centrifuge.
A Centrifuge would be useful in causing suspended particals to settle out more rapidly or even to seperate two mixed liquids into layers. That property of a centrifuge may be what you read about in treating WVO
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
  #8 (permalink)
Old 02-12-2006, 10:57 AM
1935 Ford pickup
It does not change the need for methaloxide. What I am trying to do is reduce the time needed to settle the glycerol out. When you make as much as we do it's a hassle to wait 12 hours.
The thrust of my research is to change from the batch method to a "continious-flow" process. If I can work out the bug's I should be able to put wvo into one end, and get biodiesel, and glycerol out the other without waiting for it to settle out overnight.
With my new grant we will try to build a complete plant that will fit on a car trailer, that will input wvo and waste wheat straw on one end, and produce "off-road" biodiesel and heating pellets out the other. This should alow wheat farmers to produce thereown fuel, and another product for sale[pellets for wood stoves]. FABMANDELUX.
__________________
  #9 (permalink)
Old 02-12-2006, 11:02 AM
1935 Ford pickup
Quote:
Originally Posted by leskwvo
Good luck.
Yes, mine is alot smaller. About 6" in dia, and 48" tall. The link was just so everybody could see what I was talking about. FABMANDELUX.
__________________
  #10 (permalink)
Old 02-12-2006, 01:20 PM
Fire Rooster's Avatar
Fire Rooster Fire Rooster is offline
Fire Rooster is gaining momentum as a positive member of FTE.
Fab,
Great idea. and yes I am interested. One question I have is cost. Honestly what is the cost of setting up one of your processors? Or even to purchase one? I realize this question is probably premature, just curious.
__________________
2012 F150 Screw, 2x4 XLT+, Bad Boy Black[SIGPIC]
2002 F250 CC,SB,4X4,Lariat...SOLD. 2003 X, limited SOLD
  #11 (permalink)
Old 02-12-2006, 02:30 PM
1935 Ford pickup
Quote:
Originally Posted by Fire Rooster
Fab,
It depends on how good a "scrounger" you are, and your skill level.
A little background: I've spent the last 35 years as a "packrat" If I had to move it would take at least 4, 40' containers just to move the "small stuff". 19 cars and pickups, 6 motorcycles, 8 boats [ incl, a 50',and a 36' ], an airplane + the wife's "stuff"...........you get the picture?
For skills: I've worked in R&D, racing, drag boat racing, construction, mining, logging, manufacturig, shipbuilding, farming, etc.
I have a well equipped large shop, and am semi-retired. the "stuff" I build has very little out-of pocket cost, so it IS a little hard to pin a price on!
BUT......I have had such a responce to what I have built that I'm working on a parts list and print's of the equipment so that others may build one if they choose. I'm also documenting everything on video.
As to the grant, the target cost for a finished, semi-portable plant that will produce 75-100,000 gal per year.........$25,000. That looks like alot but really isn't, 300 gal/day X 5 day/wk X 50wk/yr.
Where I live it will take 262 irrigated acres to produce 75,000 gal of canola oil. Most farms in my area are 6,000 - 15,000 acres and use approx 10,000-15,000 gal of diesel per year. When you combine that with 10,000 farms thats a huge amount of biodiesel production in one year! AND one hell of alot of farm $$$$$$$$$$ that is NOT going to some SHEIK &^%#$@!*&
Enough of my rant........as to cost, when I've finished with my parts list and drawings I will post them for all to see at no cost. I'm not in this to make money. FABMANDELUX.
__________________
  #12 (permalink)
Old 02-12-2006, 05:43 PM
No I realize you are not in it for the money but rather the same goal I am after. To save some money, and to help the environment as well as the American economy. But most of all to keep from funding the war against our American military. Believe me I understand your cause. But I also understand that you labors should not go unpaid either.
__________________
  #13 (permalink)
Old 02-16-2006, 01:52 AM
woogs's Avatar
legacylawns
Quote:
How will continuous flow work? will you have some sort of machine that heats the wvo as it flows through then continuously adds methyloxide. It will have to sort of be in batches won't it, or can the hydrocyclone continously spin out glycerin and run out bio while more wvo is being added? will you try to recover any of the methyloxide before the glycerin is put in the pellets? will you even use methyloxide? I've heard rumors of new ways to make it separate. Sorry, I could ask you questions all night.
-matt
__________________
  #14 (permalink)
Old 02-16-2006, 07:44 AM
1935 Ford pickup
-matt
Hi Matt. Yes, the wvo will be heated in a small "flash-boiler", then pumped through a "pulsed-flow-reactor" where the methanol and aquios potassium hydroxide will be injected. The resultant "mix" will be pumped through the hydrocyclone for seperation. Bio will flow into a main settling tank, the glycerol will flow into a vacuume tank for methanol seperation. After the methanol is seperated out it will be mixed with straw and pressed into pellets.
I'm also talking with a fellow in england who has had some luck with a solid catalist to see if we can eliminate the mixing of methaloxide. FABMANDELUX.
__________________
  #15 (permalink)
Old 02-16-2006, 11:03 AM
Phydeaux88's Avatar
-matt
Woogs Vegetable oil cannot be seperated into its component glycerol and hydrocrbon chains by mechanical means. They are all part of the molecule that makes up veg oil so a chemical reaction is required.
__________________
Tags
methlyoxide
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
