New carpet install
New carpet install
Have any of you installed new carpet in your truck. I just got new carpet from Stockinteriors and have it layed out in my '72. I have a few questions:
Right now the carpet goes up about 8" past the firewall cover. Should it be trimmed back and tucked under the FW cover or can it go over the cover. How did Ford do it?
If I put it over the cover then how should I finish off the top edge?
At the back the carpet goes about 1' up the gas tank covering the jack handle clip and hold-down screw thing. Should I remove these items and reinstall them on top of the carpet or trim the carpet back?
My truck has a floor shift and separate tranny tunnel cover but the hump in the carpet still seems a bit too high. Any thought on this?
Should I use a little heat to get some of the wrickles out?
Any other tips?
thanks
Any other tips?
thanks
Yeah you are right about the carpet being bigger in every direction...it sticks out of the doors by about 3".
As far as the tranny goes, the truck used to be an automatic and I converted to manual 4 speed OD tranny. The carpet is the final phase of that project. The hump cover I used is about 1 1/2" high. Is there higher covers?
Thanks
Thanks
as for the extra in the middle, the way they used to fix that was to get some very hot water and pour onto the spot that was buckling up and that would shrink the carpet. i dont know if that would help in this case. it depends what the carpet is made from. i dont think it works on synthetic.
teardropty
13
08-16-2011 10:36 PM
79FordBlake
40
04-10-2010 06:38 PM
ford66
08-21-2009 05:38 PM
howard90f150
04-03-2008 07:47 PM
