AIH delete plug for boost guage install?
Hey guys I have been reading and searching, and reading some more from this awesome site. I have my boost guage all wired up but I want know where or what is the best location? I was wondering what effects will the AIH delete plug have on my performance as well as regular driving in cold temps? I also would like to ask what I should do with the wire assembly that is already in my AIH sensor? Where did you put it? And one more final question, would I be better off with the T in the map line (pros and cons vs. the AIH)?
Thanks a bunch,
Mitch
P.S. If this helps at all I have an 02 F-250 with the 4" MBRP stainless exhaust system, Pyro and Tranny guages hooked up and running and a Superchip (high setting) I live in NE Pennsylvania.
Thanks a bunch,
Mitch
It will throw a code without a resistor wired in. You can make your own or purchase one online. The code it throws is supposed to be a soft code so it does not affect anything to do with the operation of the truck. As far as I understand the only time the AIH will turn on is below 32 F, extended idling (20 mins), and oil temp below a certain temp, with the transmission in neutral or park. The AIH is for emissions purposes and helps to rid the white smoke when left idling for a while. Hope this helps, that is how it was explained to me.
http://www.dieselsite.com/index.asp?...PROD&ProdID=48
Thanks for the advice. Right the temps are pretty cold and most of the info the site gave is current and will cause the AIH to activate. What can do to use the map line, and will I get the same results? If I do use the map line, do I need the dual relief valve offered through Black Cloud Diesel?
The other option to keep it in the MAP line is to run a regulator, not a relief valve. The MAP line regulator functions by limiting the amount of pressure the MAP line sees, just like a regulator on an air compressor. Where as the relief valve "leaks" or bleeds off the excess pressure. I've had a blow off valve, and now I have switched to a regulator. If you have the regulator, you can put the Tee for the boos guage in the MAP line as long as it's between the regulator and the intake.
It will set a code, but that code won't trigger an SES light or cause any issues with the way the truck runs. Like someone said earlier, it's a soft code.
You can get a code eliminator wire from Garrett at blackclouddieselperformance.com. If you're good with wiring, you could make your own too. I did, but after the time and expense of everything, it would have been easier to just buy the wire premade.
