Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 02-07-2006, 10:07 PM
sgrol sgrol is offline
Garage is empty, add now
sgrol is gaining momentum as a positive member of FTE.
WVO vs Biodiesel
I'm confused. Some seem to just filter wvo and add to their #2 in the tank and go on down the road. If this is possible, why would one want/need to go through the hassel of mixing, washing, etc. i.e. making biodiesel? What advantage does the biodiesel have over running wvo? I know there must be a good answer to this, I just haven't seen it.
__________________
Steve
2012 F 350 6.7 KR 4x4, SEIC Mod, Flagpole delete, Jimmi Jammers, McGard Tailgate Lock, HID
2000 F 250 7.3 4x4 CC
  #2 (permalink)
Old 02-08-2006, 04:41 AM
leskwvo leskwvo is offline
leskwvo is starting off with a positive reputation.
I would argue that WVO if done right is far simpler and less expensive in the long run. When I say done rigth that is not mixing it with #2 at all, but having a second fuel delivery system on the vehicle. Read my article on this site about running a diesel on WVO Link to Article . This will give you the basics.
Bio has one advatage over WVO. Your less likely to have issues with vehicle warranty work running Bio.
  #3 (permalink)
Old 02-08-2006, 07:17 AM
fabmandelux's Avatar
fabmandelux fabmandelux is online now
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Quote:
If you have more than 1 diesel the cost is less because you don't have to modify all of them, and I use it for home heating, and shop heat. Bio is also better if you drive short distance's. On short trips the WVO won't get hot enough to use. It also need's NO heating, I run B-80 all winter,and have not had any start-up problems down to 0deg F. FABMANDELUX
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #4 (permalink)
Old 02-08-2006, 08:11 AM
Thanks for the replys. Don't have to worry about warranty so that is out. Live in Houston so cold weather is not a big problem. The way I see it is that it basically breaks down to this:
1. Boi - has longer preparation time, don't have to heat to use, can mix w/ diesel
2. WVO - have to heat to use (for viscosity reasons), need dedicated tank so you can switch back and forth between diesel and wvo, can't mix w diesel.
Am I in the ballpark now?
__________________
Steve
  #5 (permalink)
Old 02-08-2006, 10:28 AM
WVO can mix with diesel or Bio. But then you are at the third option. In Houston that may work well for you. The temps are warm enough year round that a blend of 50/50 may be just the ticket. Maybe even higher in the summer. Do some seearching on Blending, I'm no expert but I've ready post from folks that do it.
  #6 (permalink)
Old 02-08-2006, 10:32 AM
I don't know personaly, but I have read in researching on this topic, that diesel and wvo will separate after mixing. I plan to do some small scale experimenting with this.
__________________
Steve
  #7 (permalink)
Old 02-08-2006, 10:37 AM
Take a look at this threasd from infopop
  #8 (permalink)
Old 02-08-2006, 08:09 PM
1935 Ford pickup
Quote:
Read this thread.............. Makes me REAL glad I make bio. Every one in the thread was having problems..........Half of them were mixing with GASOLINE!!!
I've made in exess of 6,000 gal, and have never had a fuel related problem so I'll stick with Biodiesel. FABMANDELUX.
__________________
  #9 (permalink)
Old 02-09-2006, 04:39 AM
Yes, that was my point. I don't blend and can't talk to the subject in any real detail so I gave a starting point for research.
I still prefer just straight WVO works great for me, no mess no fuss.
Fab what did you do with the 1200 gallons of Glycerin from that 6000 gallons of bio.
That is one of the reason I still don't think I want to brew. That and I'm lazy and would screw up the measurments. I use oil to heat my house so I could save some real bucks if I did. But so far haven't taken that leap yet. Maybe this summer.
  #10 (permalink)
Old 02-09-2006, 07:24 AM
1935 Ford pickup
Talking
Hi Erick: I burn the glycerol in a "turk" burner that supplies the heat for the process equipt and shop heat. I just received a $40,000 grant to research using the glycerol mixed with wheat straw to make pellet's for wood stoves. Should take a year to publish the result's. I will keep everyone here informed of my progress. I'm just finishing my latest project: I've found a new way of processing that won't require settling the glycerol out overnight, I can now remove the glycerol 30min after mixing, should speed up the process by a bunch! Will post pic's and the process shortly. FAB
__________________
  #11 (permalink)
Old 02-09-2006, 05:34 PM
Cool it sounds like you have a better mouse trap. I'd love to hear about it.
  #12 (permalink)
Old 02-10-2006, 12:01 PM
hott-rodd hott-rodd is offline
hott-rodd is starting off with a positive reputation.
Now bio sounds like it will be mature enough for the masses.
__________________
2005 F350 2WD SRW LB , with 220,000 miles and rolling. Studs, SCT and 4" silverline Turbo Back .
2000 f250 2wd , fuel in-tank and pre-pump mod, 6637 filter , SS HPX, Dp 80hp tune, 5" cannon . (rebuilt by my little brother RIP!)
  #13 (permalink)
Old 02-11-2006, 10:40 PM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
WVO and Diesel will seperate because they have different molecular weights.
Bio and Dino Diesel are very similar in molecular weight actually Diesel is a mixture of molecules that span a fairly narrow range of weights and Bio, which may be a mixture but has less variety than Dino, falls within the weight range of the molecules that make up Dino Diesel
WVO molecular weight is 3 times that of Dino
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
Tags
biodiesel, mix, mixing, molecular, vs, weight, wvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
