Georgia Chapter Join Chapter, Leader: ChiefM SPONSORED BY:
New guy with old trucks
Old 02-06-2006, 07:36 PM
Bryan Baxter's Avatar
Bryan Baxter
Bryan Baxter is offline
Hey everyone. Bryan here in Woodstock. I am looking at trying to find a 60's truck. I am looking at a 63 F100 tomorrow (Tuesday). A few things I paln to do are disc brakes. Is it bettter to buy a kit of stick a new frontend under it?
It has a 6 in it to put AC on it will I need to swap the motor?
I also want to switch it over to automatic.
Is there a good guide that will help me with these projects?
Thanks
Bryan
Old 02-07-2006, 06:47 AM
70blue's Avatar
70blue
70blue is offline
As far as the disk brakes I have no idea if the newer ones will interchange. Your 63 has a solid frontend and around 65 they changed to twin I-beam. I hope someone could shed more light on that. You say it has a six assumiung it is a 300 or 240 find one or the other in the scrapyard and grab the pulleys, ac bracket and what other decent ac goodies you can find. Even if you do get all the other parts you need in decent shape do not use junkyard AC hoses. Many places that make hydraulic hose can make any hose you need for the AC. Their are plenty of sixes with ac. A C4 tranny would do ok on your truck an Fmx would do even better. imo Although they are bullet proof I would stay away from the C6 trannys unless you plan to hop the engine up a little. C6s rob a little power. Whatever transmission you get make sure you grab the crossmember. Your old crossmember will more than likely be riveted in. You can grind the rivets flush then knock them out with a punch, drill them out or very carefully torch them. Your replacement crossmember can be bolted in with grade 8 bolts. You will need a radiator with a built in transmission cooler or an external cooler. You can swap in an automatic column or go with a good floor shifter. I know I have not covered everything as I am a little tired this morning and so is my mind. Hopefully someone will have something to add.
Old 02-07-2006, 07:01 AM
70blue's Avatar
70blue
70blue is offline
https://www.ford-trucks.com/forums/f...splay.php?f=52 Inline six forum.
https://www.ford-trucks.com/forums/f...splay.php?f=61 AC forum.
https://www.ford-trucks.com/forums/f...splay.php?f=40 61-66 forum.
These are a few forums where alot of the gurus on your particuliar vehicle and projects hang out. Their is some good info if you ask or read deep enough. I am sure you will get alot of good info here too. Where ever you get the best info I hope you come back and see us regularly.
Old 02-07-2006, 07:13 AM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
...Welcome Bryan to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old 02-07-2006, 07:19 AM
3broncocrazy's Avatar
3broncocrazy
3broncocrazy is offline
Welcome Bryan, good folks here - stick around and enjoy the ride....
Old 02-07-2006, 10:25 AM
GrayRanger4x4's Avatar
GrayRanger4x4
GrayRanger4x4 is offline
First Bryan WELCOME to the Ga,chapter of !!
My Aunt hsa an early 60 something ford seting in the yard {broke fram}but the last time I saw it body was in good shape and it had a running 292 v8 in it {I think it was a 292}If you like I will get some pics. of it and see if you can hual it off if you went it.Just let me know.
Old 02-07-2006, 10:33 PM
old87's Avatar
old87
old87 is offline
Welcome Bryan!
Old 02-24-2006, 11:23 PM
4xcrazy's Avatar
4xcrazy
4xcrazy is offline
welcome bryan! lots of good people here with lots of good info
