You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Hey everyone. Bryan here in Woodstock. I am looking at trying to find a 60's truck. I am looking at a 63 F100 tomorrow (Tuesday). A few things I paln to do are disc brakes. Is it bettter to buy a kit of stick a new frontend under it?
It has a 6 in it to put AC on it will I need to swap the motor?
I also want to switch it over to automatic.
Is there a good guide that will help me with these projects?
As far as the disk brakes I have no idea if the newer ones will interchange. Your 63 has a solid frontend and around 65 they changed to twin I-beam. I hope someone could shed more light on that. You say it has a six assumiung it is a 300 or 240 find one or the other in the scrapyard and grab the pulleys, ac bracket and what other decent ac goodies you can find. Even if you do get all the other parts you need in decent shape do not use junkyard AC hoses. Many places that make hydraulic hose can make any hose you need for the AC. Their are plenty of sixes with ac. A C4 tranny would do ok on your truck an Fmx would do even better. imo Although they are bullet proof I would stay away from the C6 trannys unless you plan to hop the engine up a little. C6s rob a little power. Whatever transmission you get make sure you grab the crossmember. Your old crossmember will more than likely be riveted in. You can grind the rivets flush then knock them out with a punch, drill them out or very carefully torch them. Your replacement crossmember can be bolted in with grade 8 bolts. You will need a radiator with a built in transmission cooler or an external cooler. You can swap in an automatic column or go with a good floor shifter. I know I have not covered everything as I am a little tired this morning and so is my mind. Hopefully someone will have something to add.
These are a few forums where alot of the gurus on your particuliar vehicle and projects hang out. Their is some good info if you ask or read deep enough. I am sure you will get alot of good info here too. Where ever you get the best info I hope you come back and see us regularly.
We are happy you have chosen the best source for Fords.
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
__________________
Administrator
tim.lamkin@internetbrands dot com
Life is not only time……paradoxically, it is the denial of time!
What lies behind us and what lies before us are tiny matters compared to what lies within us.
When you are down...look up...get up...and don't ever give up....
My Aunt hsa an early 60 something ford seting in the yard {broke fram}but the last time I saw it body was in good shape and it had a running 292 v8 in it {I think it was a 292}If you like I will get some pics. of it and see if you can hual it off if you went it.Just let me know.
__________________
Only two defining forces have ever offered to die for you,
Jesus Christ and the American G. I.
One died for your soul;
The other for your freedom.
Many seem to have forgotten both of them. Member of the Georgia Chapter
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
