vin decode? and other stuff
Old 02-27-2012, 08:28 PM
66gpw's Avatar
66gpw
66gpw is offline
Try posting this in the 60's Ford truck forum. Might get better help there.
  #47
Old 02-29-2012, 07:31 AM
A_Silva736's Avatar
A_Silva736
A_Silva736 is offline
Since the subject was already brought up I'll post it here
Picked up this baby from a car farmer down in King City. He didn't speak english and I no hablo Espanno. It was a real good time. Been loving this thing.
So I would like to ask to have this ford door tag translated for me, an I'll check the dog housing lip an any other places for vin's tomorrow.
E14FHA59777
then the rivet blocks at least one decimal that looks like a 0 or a D or O..(X)
(X)90 E142 389 C 12
0 4930 089 3800 720163
Thanks in advance!
  #48
Old 03-01-2012, 05:13 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
VIN: E14FHA59777 / 90 / COLOR: Blank */ E142 / 389 / C / 12 / 4930 / 089 / 3800 / 720163
E14 = Econoline (E142) H/D Cargo Van.
F = 170 1V I-6.
H = Lorain OH Assembly Plant.
A59777 = 1967, assembled December 1966.
90" Wheelbase.
COLOR: Blank.*
E142 = Econoline Heavy Duty Cargo Van with R. H. body side doors (less windows) / 4,930 lbs. GVWR
389: 3 = Medium Green Crush Vinyl & Medium Green Match Stick Pattern Vinyl / 89 = Econoline (E142) H/D Cargo Van.
C = Ford type 3.03 3 Speed Manual all Syncromesh Transmission.
12 = Ford WCR-M 9" Rear Axle / 4.11-1 / non Limited Slip / 3,050 lb. Rear Axle Capacity.
4,930 lbs. Gross Vehicle Weight Rating.
89 net HP @ 3,800 RPM
720163:
72 = San Jose (NorCal) Ford District Sales Office, where the original selling dealer ordered the Econoline from.
0163 = Domestic Special Order number. The Econoline was ordered special by the original purchaser, not "bought off the lot."
* When there is no COLOR code, the vehicle is painted a non standard color per the original purchasers request. When this occurres, the vehicle is a Domestic Special Order.
  #49
Old 03-01-2012, 08:18 AM
A_Silva736's Avatar
A_Silva736
Wow, I am forever grateful.
  #50
Old 07-25-2012, 10:43 AM
rustybug13's Avatar
rustybug13
rustybug13 is offline
Bill, you seem to be the man to come to. I need some help with mine as well.
VIN-E14th503248 WB-090 Color-M Model-E144 Body-589 Trans-A Axel-01
Thanks for any help you can give to a newbie. Dan
  #51
Old 08-17-2012, 09:48 PM
EmilBarnabas's Avatar
EmilBarnabas
EmilBarnabas is offline
Dan
It looks like that one is already in the big Econo database, including the last line of data that you did not enter.
Here is a direct link to your Econoline data.
Econoline ID
Econoline ID
  #52
Old 08-17-2012, 10:11 PM
NumberDummy
VIN-E14TH503248 // WB: 090 / Color: M / Model: E144 / Body: 589 / Trans: A / Axle: 01 / GVW: 04350 / Cert. net HP: ? / RPM: ? / DSO: ?
Welcome to FTE
E14 = E100 Van.
T = 170 1V I-6.
503248 = 1964, assembled February 1964.
90" Wheelbase.
M = Wimbledon White.
E144 = E100 Van, 4,350 lb. GVWR
589: 5 = Red Crush Vinyl & Red Stitch Pattern Vinyl / 89 = Econoline Van Body Style.
A = Ford type 3.03 3 Speed Manual all Syncromesh Transmission.
01 = Ford WCC-A Rear Axle / 3.50-1 / 2,300 lb. Rear Axle Capacity.
4,350 lbs. Gross Vehicle Weight Rating.
Cert. net HP omitted.
RPM omitted.
DSO omitted.
  #53
Old 08-29-2012, 07:36 PM
EmilBarnabas
Welcome to FTE
T = 170 1V I-6.
If the van had a 144 engine then it would have a WCC-A rear axle with a 7" ring gear. However this van has a 170 engine, which would mate with a WCC-D or WCC-M rear axle with a 7.25" ring gear. Would they have put a 7.25" ring gear in the WCC-A axle?
  #54
Old 09-07-2012, 05:13 AM
NumberDummy
Here's the info straight from the 1964/72 Ford Truck Parts Catalog:
Text Section 40.1, page 5 ~ 1964/65 Warranty or Rating Plate Code Chart: 01 (1964) Ford WCC-A / 3.50-1 / Parts list #89.
There is no WCC-M listed until 1966 (page 13): 01 = WCC-M / 3.50-1 / Parts list #89.
Text, Section 40A, page 24: Part list #89: C3UZ-4010-C .. Axle Housing, use with 144 engine & 7" ring gear // C3UZ-4010-G .. Axle Housing, use with 170 engine and 7 1/4" ring gear.
There is no WCC-D listed, period. Not for 1964/65, nor for 1966/67.
  #55
Old 09-08-2012, 09:10 PM
EmilBarnabas
Thanks
I was confused by the chart on page 1 of section 40.3 that shows a 7" ring gear for the WCC-A axle. I guess this chart is incorrect.
  #56
Old 09-14-2012, 02:56 PM
SurfVan10's Avatar
SurfVan10
SurfVan10 is offline
1961-67 Econoline Van Vin Decoder
New to FTE and looking for some help on decoding my vin so I can be certain of its specs before I start the restoration process. I've tried to do the leg work and decode it myself but have come up short when it comes to certain parts. It'd be much appreciated if someone could help me decode as much as possible. Thanks in advance! Here's the digits (pulled from the plate on the driver's door):
E14TH522274
090 E145 489 <---(MIGHT BE H89) A03
4850 85 3600 710735
  #57
Old 09-15-2012, 01:38 PM
EmilBarnabas
Find your data-plate decode here:
Econoline ID
Can you tell what color it was originally? Your van was a special order, and the paint color is not listed.
Emil
E14TH522274
4850 85 3600 710735
  #58
Old 09-16-2012, 03:47 AM
NumberDummy
New to FTE and looking for some help on decoding my VIN so I can be certain of its specs, before I start the restoration process.
I've tried to do the leg work and decode it myself, but have come up short when it comes to certain parts.
E14TH522274 // 090 / COLOR blank * / E145 / 489 / A / 03 / 4850 / 85 / 3600 / 710735
Welcome to FTE
E14 = E100 Van.
T = 170 1V I-6.
522274 = 1964, assembled March 1964.
90" Wheelbase.
COLOR blank.*
E145 = E100 Van, 4,850 lbs. GVWR
489: 4 = Light Beige Crush Vinyl & Light Beige Stitch Pattern Vinyl / 89 = E100 Van.
03 = Ford WCR Rear Axle / 4.11-1 / 2,700 lbs. Rear Axle Capacity.
4,850 lbs. Gross Vehicle Weight Rating.
85 net HP @ 3,600 RPM
710735:
71 = Los Angeles (SoCal) Ford District Sales Office, where the original selling dealer ordered the Econoline from.
0735: Domestic Special Order number. The Econoline was ordered special by the original purchaser, not "bought off the lot."
* When there is no COLOR code stamped on the Warranty Plate, the vehicle is painted a non standard color per the original purchasers order. The makes the vehicle a Domestic Special Order.
  #59
Old 09-18-2012, 10:39 AM
SurfVan10's Avatar
SurfVan10
@EmilBarnabas - Thanks for the info! The color on the inside of the van, which looks like the original is a deep metallic green. Interesting to find out it was a special order!
@NumberDummy - Thanks for all the info, I really appreciate it!!! So glad to get this information and start work. Thanks again.
  #60
Old 05-10-2013, 02:30 PM
GuszFalcon's Avatar
GuszFalcon
GuszFalcon is offline
vin number
i finally started on my project, a 1965 Ford falcon Econoline (clubwagon ?) with a V8 in the dog house
I am Europe based so not near to any refferences.
Started the engine, runs on petrol as wel as LPG.
Brakes where stuck but i remove boh front brakedisks and am now looking to buy a drum to disk kit.
I am looking for the vin number
but so far i found these numbers on the edge of the doghouse
E13TH 649687
any body have some info?
The exhaust manifold has the number CGOE 9430 - F
The valve covers have 5 bolds
What engine do you think i have ? is it a 302 ?
really appriciate any help..
cheers Gusz
Quick Reply: vin decode? and other stuff
