Wind noise
I do not have a soultion for firming up the window to the felt...but...
There was a thread suggesting using 1/4 inch plastic tubing inserted into the rubber gaskets (full length) around each door/window opening including the rear.
I did this on my X and it works perfectly. The road and wind noise is significantly reduced and the doors shut firmer.
It is a very inexpensive yet effective solution. I hope that helps a little.
