My 7.3 quit when I put it in reverse-why?
Old 02-05-2006, 02:15 PM
Highmark18's Avatar
Highmark18
Highmark18 is offline
Drove it 2 hours on Saturday, got to my destination, put it in reverse to back up, stepped on the gas and it died-instantly. Put it in park, turned the key, and it started right up. Put it in reverse, idling fine, stepped on the gas and same thing, died instantly, like someone shut off the key. Put it in park again, restarted it, and then it was fine, and has been perfect ever since-anyone seen that before?
Old 02-05-2006, 06:40 PM
jb's94f-250's Avatar
jb's94f-250
jb's94f-250 is offline
my 94f250 did that 5.8l ...the torque convertor was not unlocking ..before long it would stall at a red light or stop sign ...had the tranny overhauled and now it is alot better ,,,cost 1525.00 but hope it never happens again...tried everything before i went to ammco and they scanned it and told me the problem was ...hope this helps ???? good luck
Old 02-05-2006, 07:17 PM
lancer's Avatar
lancer
lancer is offline
My truck kinda does the same thing except it doesn't stall. It will start to lug really low like it wants to stall but if i let off the throttle it idles back up. I have it down to the torque converter to. Hope it last for awhile. I'm broke!
Old 02-05-2006, 08:28 PM
Highmark18's Avatar
Highmark18
Strange, never heard of that-interesting-
Really doesn't seem to be transmission related, but maybe?
Old 02-05-2006, 10:26 PM
day jefro's Avatar
day jefro
day jefro is offline
i accidentaly flipped my t/c override switch and it did the same thing.kinda freaky?
Old 02-06-2006, 02:06 AM
catman52987's Avatar
catman52987
catman52987 is offline
You might try a search for t/c stall if you think that that is what it is, maby someone has the same problem
Old 02-06-2006, 07:17 AM
Casey's Avatar
Casey
Casey is offline
There are a few reasons that the engine would stall going into reverse.
In order that I recommend checking:
Low trans fluid.
Dislodged internal trans filter.
Short in the wiring to the torque converter lockup solenoid.
Sticking torque converter control valve in the valve body.
Bad torque converter.
Old 02-06-2006, 11:29 AM
Highmark18's Avatar
Highmark18
Thanks, I will check into that-I am installing a Sonnex kit this week anyway, so I can check on that filter at that time-
Old 02-06-2006, 11:49 AM
Dallenx's Avatar
Dallenx
Dallenx is offline
Sounds kind of funny that it would idle while in reverse.
It only dies when you touch the throttle?
Were you able to increase RPMs while in neutral?
Don't rule out the throttle pedal sensor. They still used those on your year truck? Crawl under the dash and see how the pedal bar is attached. Just above the pivot point, where they used to connect the throttle cable, you'll see the sensor (no cable anymore). A grounding issue here might cause a similar problem.
Old 02-06-2006, 01:08 PM
Highmark18's Avatar
Highmark18
Yeah, kind of strange. It does not die when I put in it reverse, just when I touched the throttle. And only twice, it has been perfect ever since-That is why I don't think the torque converter is at fault (but I have been wrong before) I will check that pedal linkage out, is there a ground wire there I should look for?
Old 02-06-2006, 10:47 PM
Muktown's Avatar
Muktown
Muktown is offline
i agree. it sounds like when you push your pedal it hits a bare wire and shorts something out i dont know what is near the pedal assembly but that is where i would start looking
KAT_Ayanami
03-08-2022 06:04 PM
Carl Tritch
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
08-27-2016 06:39 AM
95_F2504x4_5.8
02-18-2016 08:27 PM
mhofmann86
09-22-2015 03:45 AM
Dusterdrum
1983 - 2012 Ranger & B-Series
04-23-2014 07:25 AM
Quick Reply: My 7.3 quit when I put it in reverse-why?
