1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Front End Lube
Old 02-05-2006, 10:08 AM
sportscar's Avatar
sportscar
sportscar is offline
Front End Lube/ 15k mile service questions
The Owners Manual for my 04 F250 4x4 specs Motorcraft p/n E8TZ19590A (Hi Temp 4x4 Front Axle and Wheel Bearing Grease), for the front spindles, bearings, and U-joints. Is this the same grease to use on front end joints (idler arm, etc)?
Or does any General Purpose grease work?
Thanks
EDIT. OK, after taking a peek under the truck, let my add a question. What should I be lubing at the 15,000 mile service? I only see grease fittings on the steering components and not the drive shaft yoke or u-joints. The factory Maintenance Guide says to lube the 4x4 front axle shaft u-joints....
Grease & Gravel
1983 - 2012 Ranger & B-Series
03-24-2017 09:42 PM
74Mav
05-19-2016 01:20 PM
fordman19762003
11-26-2013 11:24 AM
bakerbuilttracks
12-09-2012 11:19 PM
$undance
1997 - 2003 F150
06-12-2012 03:34 PM
Quick Reply: Front End Lube
