What is the maximum safe boost limit?
Ok here's the deal got an 06 f250 and i want to get more out of it, but i have read about blowing head gaskets with too much boost. So whats the magic number i can take the boost to and not have to worry about blowing the head gaskets? Everybody wants the most power but which tuner would allow me to put it in and forget about it no worries? I will substitute having the most power for having dependability. Help please!
chips not tunners
ford dealer told me no more than 24 lbs
now that does not mean you can go more, but that is what he said , also there are other choice's you don't have to get a tunner you can get a chip, meaning a tunner loads software in you computer to change boost, fuel ,etc there a few chips out there that trick the computer readings on the Map sensor and also send readings to you pcm to tell it to give you more fuel
try looking at black cloud diesel and check the part that say's our ford stuff,
I think its call steroid by dfuser( i dont think this unit effect boost)I have ordered one of these should have it this week. say's to give you 80+hp thats enough for me
name brand ?
i have a edge. that is name brand. that is why i want to get away from the tuner, my truck does not like them for what ever the reason. the fuel tuner, sound like it might be the ticket, for one they told me if it does not work for me they will give me a refund , also it is about 150$, less than 1/2 of what i paid for the edge. so if it works then i will be better off with this plus no program on my pcm. time will tell. i should have it on by this coming weekend
