Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.8 & 4.2L V6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 02-03-2006, 07:56 AM
jonsmack jonsmack is offline
jonsmack is starting off with a positive reputation.
Lightbulb cylinder misfire
This question is actually for my 3.8L 2000 mustang. I recently had the car to autozone and I got three different readings from the diagnostic test. I have a misfire on cylinder 2, lean running condition, and egr valve malfunction. I replaced the egr probably 70,000 miles ago and the engine light never went off, I dont know if it just never worked right or if the code has to be cleared for it to go away. Due to my inexperience I only changed the valve and I learned now that I should have cleaned the parts that lead up to the valve. Will a bad egr flow cause my other two problems?
  #2 (permalink)
Old 02-03-2006, 08:04 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a good reputation on FTE. projectSHO89 has a good reputation on FTE. projectSHO89 has a good reputation on FTE.
While it is possible, it is unlikely.
Please post the exact DTCs received for better assistance.
Steve
__________________
If your original owner's manual is missing, download a soft copy from www.fleet.ford.com under the MAINTENANCE tab.
Think about it: Ignorance can be addressed through education but you can't fix stupid! ...apologies to Ron White
  #3 (permalink)
Old 02-03-2006, 09:59 AM
travlnman travlnman is offline
travlnman is starting off with a positive reputation.
It is possible the code for the egr flow was not your valve, as many here have found out. It's usually the sensor that monitors egr flow, called a "DPFE" sensor. It's available at your Ford dealer for about $25-$35 depending onl your dealer. The f-150's actually had a recall or TSB on that part, but I had replaced mine already and was too lazy to do the paperwork to get my money back.You should be able to find some threads here about it, either under "EGR valve", or the code it shows on your scan.
__________________
Psalm27:1
Tags
cylinder , ford , misfire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
