B20 or B2? - Ford Truck Enthusiasts Forums
B20 or B2?
Old 02-02-2006, 07:06 PM
ECM's Avatar
ECM ECM is offline
ECM is starting off with a positive reputation.
B20 or B2?
My local source for biodiesel has B20 and B2. Whats the difference and which would be better for my 6.0L? Or is there no real difference.
Old 02-02-2006, 08:18 PM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Quote:
The number after the B is the percent of biodiesel, the higher the number the smoother the engine's run. I am using B-80 this winter, but will switch to B-100 in march.FABMANDELUX.
Old 02-02-2006, 08:38 PM
ECM's Avatar
ECM ECM is offline
Thanks, that's what I thought but it seemed like too simple of an answer.
Old 02-04-2006, 05:17 PM
Fire Rooster's Avatar
Fire Rooster Fire Rooster is offline
Fire Rooster is gaining momentum as a positive member of FTE.
Fab is right. I run B100 year round here in PHX. depending on where you live or travel too blending is good in winter to help keep fuel from clouding/gelling. Typically B80 blend is good.
Old 02-05-2006, 10:06 AM
bigredtruckmi's Avatar
bigredtruckmi bigredtruckmi is offline
bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.
Just remember when using the biodiesel. The ford stand is B5 max for warranty purposes. The fuel must be a ASTM D6751 which is the biodiesel fuel standard.
Check out this site for further info http://www.biodiesel.org/resources/f...arranties.shtm
Just filled up with biodiesel (B20) for the first time... lwk362393 6.7L Power Stroke Diesel 11 06-17-2013 07:14 PM
2005 Ford Escape CEL P0171 P0174 daisyq31 Escape & Escape Hybrid 0 05-08-2013 10:25 AM
Introduction/About you thread, 20 simple questions. BlueOvalDismantlers 1973 - 1979 F-100 & Larger F-Series Trucks 46 10-15-2012 07:43 PM
b20 and number 2 diesel powerstroke1869 1999 - 2003 7.3L Power Stroke Diesel 16 03-15-2008 10:52 PM
Great weekend Topic: Are you hardcore?? jake00 General NON-Automotive Conversation 39 07-17-2007 12:13 AM
Tags
350, 60, 60l, b2, b20, ford
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
