Dad, what happens if you put diesel in a gas car? - Ford Truck Enthusiasts Forums
General Automotive Discussion
Old 02-02-2006, 04:23 PM
equium equium is offline
equium is starting off with a positive reputation.
Got that call last night. Thankfully, my son did not do the pumping and it was not his vehicle. He was with his friend who put about 4 gallons of diesel into his sisters Explorer. The explorer was almost empty, so they put about 14 gallons of unleaded to thin out the diesel. It didn't start. The girl's father is not offering any help (long story). The most I can offer, is to assist in pumping out the bad fuel and trying to start it with fresh fuel. I have 3 small kids at home and don't have time to pull her plugs and flush the fuel lines.
any advice would be helpful. (and what does someone do with 18 gallons of contaminated fuel?)
Thanks everyone
Old 02-02-2006, 04:45 PM
preppypyro's Avatar
preppypyro preppypyro is offline
Posting Legend
preppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud of
Start a nice bonfire with it that or just add it to more gas! A little diesel in the gas wont hurt anything!
Old 02-02-2006, 04:50 PM
MisterCMK's Avatar
MisterCMK MisterCMK is online now
Avid Winter Hater
MisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputation
Bummer, that sucks. It should still start, otherwise siphon off 1/4 of the tank and fill it with gasoline and see if that helps.
Old 02-02-2006, 04:54 PM
JD717 JD717 is offline
JD717 is starting off with a positive reputation.
I've run a 50/50 mix of diesel in a gas engine once, it ran kinda crappy, but it DID run, till the headgasket blew when I revved it to 6k. in a ford, I dont know if it'll do anything bad.
Old 02-02-2006, 04:55 PM
The tank was damn near empty (so they say) and i thought 14 gallons of unleaded and 4 gallons of Diesel shouldn't be that bad; but the darn thing would not start. I told her to stop cranking the engine when I heard the starter turning slower. No need to add a new battery to her expense.
Old 02-02-2006, 05:01 PM
AYORK3177 AYORK3177 is offline
AYORK3177 is starting off with a positive reputation.
How did they manage that? The nozzle on diesel pump is larger so it wont fit in the filler hole on an unleaded vehicle. Did the truck stop running and they assumed they made the mistake?
Old 02-02-2006, 05:06 PM
Quote:
When I got to the station, the first think I did was pop the fuel cap off. Guess what was missing? Yep, the restrictor plate. I asked the girl what happened to it. "Oh, that broke off a long time ago". At least we wont have any trouble getting a hose/tube down there to siphon it out.
The boys realized the mistake after pumping in 10 bucks. (at 2.79 gallon=3.58 gallons) They talked her into starting it after I told them it should run, but it'll run rough and loud. It never kept running.
Old 02-02-2006, 05:13 PM
Agronomist's Avatar
Agronomist Agronomist is offline
Agronomist is starting off with a positive reputation.
Gotta tell this story... Dad back in mid 70's was running empty on gas and zoomed into the farm supply business and he put diesel in his new xtra cab Ford and off he went to a near by town. Nozzles were the same at the co. pumps. 1/2 way there he said he glanced in rearview and the exhaust was running black as coal. Pulled into where he was to visit customer .. turned the key off. The engine kept on running. Went and topped it off with gas. Kept that truck a long time. Hope all is ok with your car.
Old 02-02-2006, 06:14 PM
A_G's Avatar
A_G A_G is offline
A_G is starting off with a positive reputation.
My dads truck has been running bad for so long. Actually its running so bad it sounds kinda like a diesel. Anyways. He and i wanted to try and see if 1 gallon of diesel mixed with the rest gas in the gas tank. to see if it would run better. It actually did run alot better for about 3 weeks.But it did run funny for that tank. (8 hours)
Old 02-02-2006, 10:00 PM
jimbeamalki jimbeamalki is offline
jimbeamalki is starting off with a positive reputation.
My daughter did same thing in 1996 with an '86' Tempo. She got about 2 blocks before it quit. I drove from Indianapolis to north of Ft.Wayne In., in my junk 79 Ranchero (+120 miles) ---4 degrees above 0 and a lot of snow- 1 a.m. Drained the tank (she was near an on ramp for the interstate), put in 5 gallons of gas but never got it to start. Cop came by and gave me an hour to get it out of there or get it towed. Towed it all the way back to Indy to a Ford dealer who fixed it for $150. Daughter said it was the coldest night of her life steering that non-running car while being towed for 3 hours. I said "Serves you right" Flash back to 1970--had a 57 Ford and it quit on a road trip on the way back from Michigan. Dad came the next weekend in his 68 F100 and took me to pick it up and tow it home. Yep---4 degrees above zero and a bunch of snow. Froze my *** off steering that non-runner, and Dad said "Serves you right". Guess what goes around comes around.
Old 02-02-2006, 11:26 PM
rbohm rbohm is offline
rbohm is starting off with a positive reputation.
there actually were gas stations that sold gasoline that had a 3% mix of diesel in the gas. this was back in the late 70's. the problem with putting diesel in a gas engine is that on a cold day or night, the diesel will gell and clog things up causing a no-start problem.
Old 02-03-2006, 12:31 AM
A_G's Avatar
A_G A_G is offline
Wanna hear something ironic. Not 20 mins after posting my above post. My water pump took a dump on me...
Old 02-03-2006, 06:18 AM
Snake1979 Snake1979 is offline
Snake1979 is starting off with a positive reputation.
Ha, 4 gallons of diesel, thats nothin.
Try 20 gallons of pre mixed outboard boat fuel. Or how about 5 gallons of pure moon shine.
Both things my grandfather put into his, then my 81 F-150.
I swear if you were hard up you could drop your, "Man spigot" into their and fill it up a little and the truck would start.
Old 02-03-2006, 08:16 AM
94_turbo 94_turbo is offline
94_turbo is starting off with a positive reputation.
well--some of you may flame me--but if it was mine--with that low a concentration--id mist a little ether to it to get it to start--the dsl may be setting on the bottom--and needs just a little help to get started--after starts--id go down the road bouncing the steering wheel back and forth a few times to get it to mix--then run it till at least fully warm--would think it should start after that as the concentration is so low--
cleatus12r cleatus12r is online now
cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.
I don't know what the deal is....
I've run 8 gallons of diesel to 5.5 gallons of gasoline in my 91 Cutlass. Runs ok, but doesn't like to start when it's cold. Smokes on deceleration and stinks a bit but big deal, the fuel was free.
Story behind the story:
These guys who buy Duramaxes (must be a Chevy buyer thing) will inadvertantly start filling their tanks with gasoline then realize that they messed up 10-15 gallons into the fill. Oops. Here comes the tow truck. We drain the tanks and fill our own cars with the mixed fuel. Depending on the amount of fill, the mixture has been as high as 65% diesel, 35% gas. My commuter car still runs just fine on it and it doesn't cost me anything.
My guess on the dielmma at hand (Explorer) is that the initial concentration of diesel fuel was too high to start the engine. I'd bypass the fuel pump relay, hook a battery charger to it and let the fuel pump run for an hour or two to mix the fuel up (fuel return will do it).
Cody
I am an idiot please help. caverjoe 6.7L Power Stroke Diesel 44 03-30-2014 10:28 PM
Need help water in fuel. Rishsd 1999 - 2003 7.3L Power Stroke Diesel 31 06-06-2013 07:53 PM
Diesel / Gasoline "safe" dilution ? dieselcontam General Diesel Discussion 17 06-09-2011 02:41 AM
Just put diesel fuel in my truck by mistake.. WesternHeel General Automotive Discussion 16 01-25-2005 05:04 PM
93' f-150 fuel pump problem..... maybe..... GmanPride45 1987 - 1996 F150 & Larger F-Series Trucks 60 11-30-2002 09:16 PM
Tags
car, deisel, deisl, diesal, diesel, disel, f150, f250, ford, gas, gasoline, put, putting, runs, truck, unleaded, vehicle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
