Banks Power Elbow????
There is a compressor wheel (Intake) and a turbo wheel (Exhaust goes thru, this is the drive turbine). The power elbow requires the Banks downpipe because it is a larger diameter. It gets rid of your EBP valve on the outlet housing, opens up the diameter and has a batter shape for airflow. I run one, but I am not convinced it makes a noticable change. I also run banks compressor wheel. The purpose is to allow free-er flowing exhaust and more boost...and it makes the turbo a good bit louder to boot...lol. The power elbow is not a fun install, it took me and 2 other guys the better part of 6 hours in an Excursion..and we were sweating it bad! I kept shattering the 5/16 Craftsman sockets on the EBPV housing trying to get it apart. I ended up welding a socket back together and tack welding it to the heads of the 12 point bolts. I ground it off and welded it to the next one. It sucked.
If your mechanicly inclined and have a good shop set-up you can get it done no matter how hard, if your in your driveway with a simple set of tools...it could turn out ugly. You do need to remove the turbo, at least I did...I saw no way to really get it done in the truck (I know it has been done without removing the turbo....God bless you poor guys that did that...).
I would have paid the 200 bucks for frdtruckpullers truck to be done! That sucked! I had bruses all over my chest and stomach from that experience. Thx again Larry. We sell that stuff and tell everyone the same thing. Its a nice piece if you have a freind doing it lol. Then again they may not stay friends long. hehe
If I were changing the compressor wheel and outlet...I would never leave the stock housing on. You can do the Banks housing/wheel/outlet at the same time and ask your mechanic for a deal on the entire job. Its not much more work to swap housings...
Here is the description on the Banks housing:
Quick-Turbo housing
Banks developed the Quick-Turbo in conjunction with the Holset turbocharger and major diesel-engine companies, to eliminate sluggishness "out of the hole" and produce strong acceleration. Quick-Turbo produces massive torque right from idle, achieves a higher peak faster, maintains more boost through the powerband, and doesn't over-boost. Picture of the housing/wheel kit..
The picture below shows stock wheel on the left:
Notice the 5 large/agressive main vanes on the banks unit on the right? That things hooks into some air! Same as a wickwed-wheel...
As for the power elbow...
Banks Power Elbow Assembly
Remove the final restriction to power
Banks Power Elbow assembly slashes the stock outlet and pipe backpressure by 40%. Available separately or with Banks 4-inch Monster Exhaust. Includes: Cast, large-bore elbow housing; Stainless, 3.5" Monster T.O.P. turbine-outlet pipe with ceramic-matrix heat shield; Mounting hardware; Comprehensive Owner's Installation Manual.
Quick-Turbo housing
Dude...this will make stall something you think back on and wonder if it was real...or just something you imagined. I tow a 13,500 lb trailer with my 7.3 Excursion with this stuff. I use a lvl 4 big Hoss chip and a 6-gun tuner on lvl 6 WHILE towing. I have guages and I am straight piped. My EGT's are not an issue, I would be willing to remove my EGT guage and I would still pull my trailer.
I have a 30' bumper pull trailer 3,500 lbs
79 F-250 pulling truck 5,800 lbs
2,200 lbs of tractor weights
a 4x4x8 shed built on the trailer that I have a generator, compressor, 4 spare tires, 4 ton floor jack, and every hand tool and air tool you could ever want for.
I pull a heavy load, and trust me I pull it hard! Stall....surge.....nope.
the wicked wheel is all you need to eliminate the surge problems. the larger turbine housing and the power elbow are just to improve flow on the top end, for less backpressure, which means more power with less boost (restriction). the "quickturbo" exhaust turbine housing is 1.00A/R, correct?
