Quote:
Originally Posted by 01 PSD
Thanks for all the help guys. This site is great! Are we all in agreement that the #1 injector is the front on the passenger side?
Yes it is.
Do yourself a favor and get a mity vac or some other device that can draw fluid out of a small hole. I have done two injectors in two seperate jobs and here's my 2 cents:
Don't mess with the plug on the back of the head unless you want to. There is some fuel in the rails but it can be dealt with pretty easily as you will read.
First pump the oil out of the high pressure oil pump reservoir. It's about a quart or so. The plug on the top can be removed for the Mity Vac to gain access.
You do need to remove the plug that is on the head that leads to the high pressure oil rail. It is drilled in-line with one of the injectors and faces the lifter valley. You will want to use the Mity Vac to suck out all the oil in the head, it will be another quart or so.
Get three rags or paper towels. Have them ready to go, sitting right there next to you. The second you pull the injector, stuff a rag into the hole. Wait 5 seconds. Pull that rag out and stuff another one in there. Wait 5 seconds. Pull it out and stuff the third one in there. Leave it there for now. Between pumping the oil you can out of the rail and the rags soaking it up, you will have captured about 90% of the fuel and oil that would have drained into the cyl.
Mity-vac what you can out of the cyl and also pull the glow plug and turn the motor over by hand a few times with a breaker bar. A nice little mist will spray up and out letting you know it's ok to put the glow plug back in. It is an excellent time to put in new glow plugs.
Before you put the injector back in, spray a little brake cleaner down the hole. It will blow any tiny bits of crap down into the cyl so the copper gasket on the new injector can get a good seal.
After you are done getting the truck back together, warm it up then run at 3300 RPM for about 10 miles to work the air out of the oil rails.
BTW, you can get NEW Alliant Power Injectors for about $200 versus the rebuilt ones the dealer will sell for nearly twice that. Alliant is OEM.
