'99 Ranger 2.5 4cyl Spark Plug Change... - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 02-01-2006, 09:48 PM
Paul Borowski Paul Borowski is offline
Paul Borowski is starting off with a positive reputation.
Angry '99 Ranger 2.5 4cyl Spark Plug Change...
Holy Mary Mother of God-what a freakin' nightmare-you wouldn't think a four cylinder engine would be that BAD to do, but damn are my hands sore and scratched up!!! The two rearward driver's side plugs are unreal!!! Took about a 1/2hr on just each one!!! This engine has "two plugs" per cylinder and is also a non-A/C truck. I could hardly imagine how worse it would have been if my Ranger had A/C!!!
Old 02-01-2006, 10:00 PM
CoolBenge CoolBenge is offline
CoolBenge is starting off with a positive reputation.
Paul,
Tell me about it! I changed the passenger side plugs and plugwires 2 days ago. I haven't mustered up the courage to tackle the other side yet.
Tim
Old 02-01-2006, 11:05 PM
Tim, the two front driver's side ones aren't bad, but then again my truck does not have A/C. Those two driver's side rearward ones under the intake plenum are a B_tch!!! Have fun, I know I did.
Old 02-01-2006, 11:24 PM
lurchy98's Avatar
lurchy98 lurchy98 is offline
lurchy98 is starting off with a positive reputation.
My truck does have a/c. Took a while and a few choice words but I finally got them changed, the sad thing is the time is coming up to change them again because it's been about 60k miles since they were last changed.
Old 02-02-2006, 06:31 AM
Bart99GT Bart99GT is offline
Bart99GT is starting off with a positive reputation.
I would suggest just removing the upper half of the intake manifold the next time you do it. There are two vaccum connections to disconnect and a couple of wiring plugs. Unbolt the EGR tube and leave everything else in place. It makes the job vastly easier!
Old 02-02-2006, 08:22 AM
AlfredB1979 AlfredB1979 is offline
AlfredB1979 is starting off with a positive reputation.
From what I've seen in that intake area, with the proper swivel and whatnot, this doesn't look too terrible of a job. Maybe my fingers are long or whatever, but I reached in at the plugs just fine. I know that doesn't make for the whole story, but I'm hopeful in 11.000ish miles....
Since my mechanic friend changed the plugs before I got the Ranger, I will take his word (and his tools) for it.
Old 02-02-2006, 09:16 AM
99F150 99F150 is offline
99F150 is starting off with a positive reputation.
I was going to try this my self then thought better of it and took it to shop I trust.
I watched him change them and no way was I going to get them out with the few tools I have. He used four different wire pullers and the set up of swivels for that drivers rear plug was something.
I hope not to have to do it again any time soon as I put in Autolite double platinum plugs, but if I have to do it my self the top half of the intake will come off.
Old 02-02-2006, 08:42 PM
natebaker's Avatar
natebaker natebaker is offline
natebaker is starting off with a positive reputation.
I took the top half of the intake off. It took 10 mins for the first 6 plugs and 30 mins for the 2 rear, driver side plugs. Not that bad. I'll definitely do it myself instead of paying someone else to do it.
Old 02-04-2006, 08:54 AM
Question
Quote:
...when you take that "top half" of the intake plenum off, isn't there a gasket there that has to or needs to be replaced???
Old 02-04-2006, 11:17 AM
el conquistador el conquistador is offline
el conquistador is starting off with a positive reputation.
yes there is
Old 02-05-2006, 02:00 PM
nobrandx nobrandx is offline
nobrandx is starting off with a positive reputation.
Cool
I just did my plugs last night, although I have the 2.3L version-89 Ranger it was still a pain in the backside, I found that the the plugs were OE along with the wires, the wires still have 1989 on them, th eplugs were really wore out, but none the less a big pain in the backside to do
Old 02-09-2006, 02:17 PM
mburec mburec is offline
mburec is starting off with a positive reputation.
I am NOT looking forward to doing the plugs and wires on my 1999 2.5L Ranger w/AC. I couldn't imagine any plugs being harder than my 1995 Probe GT was, but the ranger ones look like a REAL pain!!
Old 02-09-2006, 03:57 PM
Plastic Plastic is offline
Plastic is starting off with a positive reputation.
I just changed mine (96 2.3L, 120k) for the first time. I did the front 3 passenger with no problem using a 6" extension. Fourth was a tight fit against the wall with that extension, but it worked. Front driver's side came out easy, using needle-nose to pull on the the plastic extension. Second driver's side was the only one that required a wobble extension to get the centimeter or so clearance from other parts in line with the angle of the plug.
I did the last two in about 10 minutes using a long pair of needle-nose pliers to pull the boot off using the plastic extension attached to it, pulling it right out through the gaps in the upper intake - the angles on the plugs were designed to make getting to the plugs easy using a couple of extensions (I used 10"+6"). Didn't have to try to squeeze any fingers in there. This is not as bad as it looks!
Old 02-09-2006, 08:40 PM
natebaker's Avatar
:O the gasket has to be replaced when you take the top half off? Crap... It's been 6 months and I haven't had any problems whatsoever out of it. Add that to my list of things to do.
Old 02-11-2006, 09:01 PM
towmaster towmaster is offline
towmaster is starting off with a positive reputation.
When i changed plugs on my brother's 1995 Mazda B2300 I had to remove the belt and undo the 4 bolts that hold the A/C compressor on, and move the compressor aside to get the front driver's side plug. The truck had dealer installed A/C though.
2001 Ford Ranger 4.0L V6 cylinder 3, cylinder 2 misfire. HALP. NOWAYBUTUSA Ranger & B-Series 6 05-16-2015 07:24 PM
Ford Ranger, pouring water on ground. lyger Ranger & B-Series 10 08-11-2013 11:32 AM
1986 Ranger 2.3 gas-putting & stalling after replacing spark plugs bozo4ford 4 Cylinder Engines 60 10-24-2012 06:13 AM
1996 Ranger XL Fan Shroud Denny Joe Ranger & B-Series 3 07-10-2012 09:46 AM
2004 Ranger 3.0 misfire bearring1 3.0L V6 3 02-18-2010 11:22 PM
Tags
1999, 25, 4cyl, 99, change, ford, gap, platinum, plug, plugs, ranger, spark
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
