Compatibility / Interchangability Guide for Ford Radios -- is there such a thing? - Ford Truck Enthusiasts Forums
Old 02-01-2006, 09:32 AM
222925 222925 is offline
222925 is starting off with a positive reputation.
Hi:
I have a 2002 F250 with a 6 Disc Player that has gone bad. I want to replace it with a Cd Cassette Player that I think may be less prone to problems (less moving parts).
My problem is, in my search I have found (on the internet) people who are selling units know nothing about compatibilty and often don't provide a clear picture of the side and rear of the unit to determine if it has the same harness plug and mounting bracket as is required for my truck.
Is there a source (internet site) that a person could use to check radio model numbers for compatibility with existing wiring harnesses / mounting brackets already installed in a specific Ford?
I think this would help a lot of people.
Also, if it is not available, one of you radio guru's with web sites could get a lot more hits on your sites if you made or tied a site like this to yours!
Thanks
Old 02-01-2006, 06:35 PM
RangerPilot's Avatar
RangerPilot RangerPilot is offline
RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.
I'd look at Crutchfield for the aftermarket adaptors that convert your aftermarket radio signals to the speakers and amp and stuff. If it lists one adaptor for all types of radios, they are all the same. I know that seems complicated, do you get what I mean? If it lists the same part number for the 6 disc changer and cd/cassette player, it'll work.
Old 02-01-2006, 07:04 PM
IPACA9's Avatar
IPACA9 IPACA9 is offline
IPACA9 is starting off with a positive reputation.
Call Kelvin at Broadway Radio shop. My old employer. They are and authorized Ford radio service center. They would know. 816-753-1960
Old 02-01-2006, 07:15 PM
I found a site: "Radios and More"
http://209.238.89.122/product_Spec_S...18c815-ab&RB=1
Where you can get the specs for a CD / Cassette / Radio -- the address above can be altered to match your radio -- the one above is for my 6CD radio in my F250. I called the store and he said if the plug type, harness repair kit and attachment device are the same, they are compatable. Thus, I now know that any Ford that had a 5L5T-18C868-AA can also plug in my 1c3f-18c815-ab and Visa Versa. The site also lists the Fords that the radios were iinstalled in, but this does not mean the list is all the radio will fit in -- the list is just the production years they were factory installed.
I'll have a look at the site you mentioned and see if I can learn more -- Thanks!
Old 02-01-2006, 09:38 PM
Good site, will wind up being helpful to someone in the future.
CD Player says CD Error and DVDs sticking stickthrower 1997-2006 Expedition & Navigator 0 09-19-2016 10:06 PM
Several Solutions To Deal With Radio Signal Receiving Problem Of Car DVD Amanda Vivi 2007 - 2014 Expedition & Navigator 1 03-20-2015 05:45 PM
Replacing radio in 97 Ranger with radio from newer truck--wiring adapter? IronHorseDriver Electrical Systems/Wiring 2 06-11-2011 09:43 PM
Radio interchangeable? evg1973 Ranger & B-Series 5 08-13-2010 11:55 AM
Aux input harness? n5926g Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 4 08-06-2010 07:59 AM
Tags
1998, cd, changer, chart, compatibility, compatible, f150, ford, list, match, part1c3f18c815ab, radio, radios, stereo, stereos
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
