Manual tranyy issues
Old 02-01-2006, 08:10 AM
Elephantman727's Avatar
Elephantman727
Elephantman727 is offline
Unhappy Manual tranyy issues
I just bought a 1999 F-150 4WD manual trans with 63000 miles on it and the tranny just started makeing noise. With the clutch engaged and the tranny in neutral it sounds like a clicking that varries with RPM...which goes away when I disengage the clutch. Also 4th gear has a lot of gear chatter.....any suggestions would be greatly apreciated........
Old 02-01-2006, 08:15 AM
mat-helm's Avatar
mat-helm
mat-helm is offline
Sounds like the thrust bearing going bad. That's the bearing that pushes against the clutch when you press the pedal.
Old 02-01-2006, 08:23 AM
Elephantman727
Unhappy Just replaced
The hydraulic throwout bearing assy was just recently replaced for that very reason.....I'm haveing a sinking feeling that the problem is with the hardparts within the tranny iteslf..........
Old 02-01-2006, 08:35 AM
mat-helm's Avatar
mat-helm
mat-helm is offline
Go by your local "cheap tool" supply store ( harbor freight) and pick up a sethascope so you can narrow down exactly where the noise is coming from.
