CarQuest coolant filtration?
The local CarQuest dealer is selling a CarQuest filtration system, no hoses or engine fittings, for $20. It is a spin on canister unit and comes with the filter mount, 1 cartridge (order with or without SCA charge) and some hose fittings for the mount. I can put the whole thing together for about $40 and will probably have to make a steel bracket for the mount. (powdercoated of course )
Anyone looked, heard about or used this system? pros - cons?
on
i am sure it is the same system that napa offers with a cast iron filter head and some fittings. works great! i pretty much just used the head then plumbed everything else from what i have in the shop. check my gallery to see what i have. it is an OBS so it will be a bit different but not much.
Now I have to do some research on where to tap the inlet and outlet.
Originally Posted by guzzle92
for the info...When I went to NAPA, just got a blank stare.... CarQuest just had a pic from their catalog but it looked more like a Racor head, maybe cast aluminum? The 90º hose fittings did look the same though. I figure with a simple bypass system on coolant, I wouldn't need somthing real fancy.
OK, I picked up the coolant filter and let me start out by saying the counter guy screwed up with the quote yesterday. He quoted me fleet pricing. I stuck to my guns and made him honor the quote he gave me. The list price on the base unit was $76.11 and the price I got was $20.15. Wow, what a markup!
The filter base (they have it listed as 'conversion base') #CFI 89019
Filter element - non-SCA charged since I run the gold: #CFI 89070 $5.95 (list - $22.48 (nobody pays this!)
3/8 hose, fittings, 12 clamps and I walked away for $56.52 including tax.
They have both SCA and non-SCA filters. The 89070 spin-on is 5 1/4" tall x 3 3/4 in dia. They have a shorter spin-on and I may go to it after running the larger one for a year. The base is painted a turquoise-green color - that's gonna go for sure, and is machined cast iron. Very heavy piece. The casting has a number, 111103/1 cast into it and is probably the same part many other vendors sell.
