Traction bars
http://broncograveyard.com/products/cat/18/120/23610 I got these for my 79 f 150 4x4 and no more wheel hop at all. I went with them cuz i found other people that used them and no one said nothing bad about them. There are heavier duty ones out there but i didnt have much to spend on them. Easy to install just drill a few holes if i remember correctly.
I am running skyjacker traction bars on my 79 F-150 shortbox. Got them from Rockymountain Suspension. Worked great with the stock 351M/4:11 and later with the swapped 460 and the 4:56 gears. L&L seems to have a good set of ladder bars but they might be pricey. A good shop can make you a set for not too much. Bronco Graveyard has a set marked as Superlift track bars. that dont impose any clearance problems and do really well also.
JWILL
Central Iowa
JWILL
Central Iowa
seneca
04-21-2006 07:50 AM
