removing the race from a rotor?
Bought new front bearings today (yes I remembered the grease seals). I bought the set that has the bearing and the race. Just exactly how to you get the old race out? Is there a lip or something that you can put a drift on to carefully punch it out? Are there any secrets to make this job easier?
94 4X4 explorer.
Thanks in advance.
Matt
94 4X4 explorer.
Thanks in advance.
Matt
Yes there is a small lip that you can punch against from the back side. I always like to use a brass punch, but sometimes it will require a steel punch. Remember to work around the race, opposite sides for each drive, and move just a little bit at the time. If you try to go too much on any one spot, it will **** to the point of being very difficult to remove. I also try to always use a small hammer (helps with only moving a little bit each time).
