How to remove 50 year old hardened, caked oil? - Ford Truck Enthusiasts Forums
Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Old 02-15-2002, 04:13 PM
cigarxtc's Avatar
cigarxtc cigarxtc is offline
cigarxtc has a great reputation on FTE.cigarxtc has a great reputation on FTE.cigarxtc has a great reputation on FTE.cigarxtc has a great reputation on FTE.cigarxtc has a great reputation on FTE.cigarxtc has a great reputation on FTE.
Old 08-11-2002, 12:17 AM
pcmenten pcmenten is offline
pcmenten is starting off with a positive reputation.
I've got a 56 Ford Fairlane that I've been trying to clean. I have been chipping caked on grease; it's hard as a rock! The grease is actually motor oil that came from the engine's road draft tube.
I've tried a pressure washer (to no avail), wire brushes, and Craftsman screwdrivers. The screwdrivers are most effective at removing it, but it's tedious work and it scratches the metal.
The only solvent that seems to soften the stuff is WD-40 (I've finally found a good use for WD-40!). Any other ideas?
TIA,
Old 08-11-2002, 12:50 AM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
There are several threads here on parts and engine cleaning, give them a look see.
Old 08-11-2002, 04:32 PM
Quadiquizm's Avatar
Quadiquizm Quadiquizm is offline
Quadiquizm is starting off with a positive reputation.
Take it from a guy who has worked on old farm equipment...
Soak the grease in diesel fuel - it softens it up - and then go nuts with the pressure washer. Remember Soaking longer is always better.
But when you get to the really tough stuff - its scraper time!
My Two Cents!
Old 08-11-2002, 06:52 PM
truckertaz's Avatar
truckertaz truckertaz is offline
truckertaz is starting off with a positive reputation.
I have to agree with quad soaking in fuel is the best choice and a good pressure wash is about you best bet
glad to see another Monty fan!!!
"your mother was a hanster and your father smelled of eldaberries!!"
Old 08-11-2002, 10:42 PM
Thanks for the replies, guys.
FYI, I was cleaning the 45 year old 292 short block. It, too, had hardened grease caked onto it. I realize now that the hardened grease is just like asphalt; a mixture of tar and sand. Jeepers, that stuff is hard to loosen.
I mixed a solution of Red Devel lye and laundry detergent in water. Works great on the grease, but it's rough on the hands.
I'll try the diesel fuel tomorrow, maybe mix it with lye and detergent. I'll post the results.
Paul
"Go away or I'll taunt you again."
Old 08-12-2002, 12:42 AM
fordtrucksforever fordtrucksforever is offline
fordtrucksforever is starting off with a positive reputation.
Post How to remove 50 year old hardened, caked oil?
Your leftover auto tranny fluid makes a very good degreaser. Soak the area well and then pressure wash it clean. i have used this with very good results. Cant beat the price and much easier to wash away than you might think.
Old 08-13-2002, 10:35 PM
Gannet's Avatar
Gannet Gannet is offline
Gannet is starting off with a positive reputation.
Well you could use some Benzene or 1,1,1-trichloroethane ...Just kidding! Try some elbow greese! Only thing I can think of.
Old 08-14-2002, 11:14 PM
jerrykelley34 jerrykelley34 is offline
jerrykelley34 is starting off with a positive reputation.
[updated:LAST EDITED ON 14-Aug-02 AT 11:16 PM (EST)]Knock off the big stuff and try oven cleaner. For final clean up before paint use lacquer thinner and astiff parts brush,followed by soap and water.JK34
Old 08-15-2002, 08:39 AM
TheWiz427's Avatar
TheWiz427 TheWiz427 is offline
TheWiz427 has a good reputation on FTE.TheWiz427 has a good reputation on FTE.TheWiz427 has a good reputation on FTE.
Ditto JK34 i to have had very good results with oven cleaner(easy off)spray it on and let it sit then pressure wash.Unfortunatly the tough stuff has to be scraped.
"Wink wink,nudge nudge,say no more say no more!!"Gotta love M P
Wiz
An Equal Opportunity Truck Lover!
http://www.clubfte.com/users/thewiz427/index.html
Old 08-15-2002, 01:35 PM
76supercab 76supercab is offline
76supercab is starting off with a positive reputation.
Ya know, the way that leaking power steering fluid ate up my new asphalt driveway.... might be worth a try.
Old 08-18-2002, 11:38 PM
Earl's Avatar
Earl Earl is offline
Earl has a good reputation on FTE.Earl has a good reputation on FTE.Earl has a good reputation on FTE.
[updated:LAST EDITED ON 18-Aug-02 AT 11:40 PM (EST)]Aw, heck Paul - I just go after it with a grit blaster. MORE POWER - Uuuhhh Uuuhhh Uuuhhh.
It takes longer to remove the crud than to remove rust since the crud absorbs a lot of the impact energy of the grit but it's a lot easier on my old elbows and hands than scraping it off. On the other hand, it's a lot harder on the paint and anything else you may not want to remove!
So take that baby out back on a BIG plastic sheet, jack 'er up on BIG stands, and have at it with a BIG grit blaster! Nothing like a little wanton destruction with MORE POWER to do your soul some good.
Oh yeah, put your beer back in the shop before you start unless you like crunchy stuff at the bottom of the can.
George
"Some call me ... Tim." ... Monty Python Group
Old 08-24-2002, 02:42 PM
Opera House Works Opera House Works is offline
Opera House Works is starting off with a positive reputation.
I found a trick to use with sludge caked on the inside of valve covers by accident. I would lightly wash the inside of the valve covers with a paintbrush and gas, wait five minutes and do it again. Drain all the liquid off, and lay the valve cover out in the hot sun for about four hours. After that, I would lightly tap the cover with a hammer. All the sludge, even the stuff behind the baffels, would fall off and you would be left with bare metal. No scraping or other work. The gas dries out the varnish and it shrinks and cracks in the sun. Any disurbance then makes it fall off. Probably works with just smoothe surfaces.
Old 09-02-2002, 03:23 PM
bcguys bcguys is offline
bcguys is starting off with a positive reputation.
Beware of highly flammable degreasers (lacquer thinner). My hose didn't quite reach so I moved the vehicle a little closer and discovered how to make a car go woof.
Todd.
Old 09-02-2002, 03:49 PM
Torque1st's Avatar
Posting Legend
OOOPS! What happened?
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 04:27 PM
Can someone explain this to me? 1987 - 1996 F150 & Larger F-Series Trucks 11 03-09-2016 01:40 PM
ooops Aerostar 5 01-14-2015 04:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 07:14 AM
DPSE Roachfood 1987 - 1996 F150 & Larger F-Series Trucks 3 03-11-2002 11:21 PM
Tags
block, caked, car, clean, engine, engines, fro, fuel, grease, hardened, motor, oil, remove, removing, vehicle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
