Fuel Injector Electrical Connector Gasket.
I noticed yesterday as I was changing my plugs (02 F-150 5.4L) that some of the injector electrical connectors had a little rectangular red gasket in them and some of them didn't. I cannot find anyone who sells just the gasket; the dealer says you have to buy the whole harness. I didn't notice any corrosion on the connector, so I'm wondering if I should even worry about trying to find a similar gasket or make my own?
Most likely you won't find any auto parts shops who'll sell you the gaskets but they are just silicone o-rings. You should be able to find them. One place I was able to get this type of o-ring was a heavy equipment shop for Catapillar. I would recommend replacing them if you can, they keep the moisture off the connections
The red gasket is a water seal. When the connector is unplugged, this gasket should stay in the wiring harness connector.
What you are describing is the gasket on some of your wiring connectors stayed on the injector and others stayed in the wiring plug. Take a look to see if this may be the case. If so, then put the seals back into the wiring plug before plugging back into the injector.
jdneal88
16
01-02-2017 12:35 AM
holdendaniels
03-20-2016 06:04 PM
