Distributor Vacuum
Mine was, then I moved it to the vacuum tree and it improved my throttle response. This was a non egr carb set-up. timing at 10 btdc. however the timing might be off, as I mix-matched every year known to stick it into my 79 bronco. I would try sticking a pipe cleaner up the DIST vac. port and see if it clears up.
BigSexy78
02-05-2017 05:45 PM
BigSexy78
02-04-2017 06:06 AM
alchemist1
06-27-2013 04:08 AM
