Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 401, 477, & 534 SD Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 01-29-2006, 07:05 PM
grumpy1 grumpy1 is offline
Garage is empty, add now
grumpy1 is starting off with a positive reputation.
534 or 330?
I have found a 1965 f500 and am considering buying it. The guy that ownes it says it has a 330 in it which was available in 1965. The vin for this truck is f50r673096 and according to my book it says it is a 534. I have done a little research on the 534 and I have found it to be somewhat undesireable. Is there a way to tell the difference between a 330 and a 534? Thanks for your help.
__________________
Aaron
  #2 (permalink)
Old 01-30-2006, 01:51 AM
Louisville Joe Louisville Joe is offline
Louisville Joe is gaining momentum as a positive member of FTE.
I would say it's pretty much certain that truck has a 330 if it's the original engine. The 534 was in the 850 and 900 series trucks.
  #3 (permalink)
Old 01-30-2006, 10:06 PM
I think you are probably right. I still can't make since out of the vin saying its a 534. I don't know if the vin is on the door on 65s or not but I was thinking that maybe the door was changed at some point. I would still like to know if there is a way to tell between a 534 and 330 though.
thanks
__________________
Aaron
  #4 (permalink)
Old 01-31-2006, 03:27 AM
The 330 is a member of the 'FT' family. It's a lot like a 361 or 390 in appearance. The intake manifold goes under the valve covers if you look closely. The Super Duty 534 is a huge engine. Much bigger than any V-8 you would see in a car or pickup truck. Also, I think all the 330's had 2bbl. Holley carburetors. The 534 had a Holley 4bbl..
  #5 (permalink)
Old 01-31-2006, 04:04 AM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
count the valve cover bolts. 5= a FE engine.
Tags
534, duty, ford, intake, manifold, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
