What size wrench/socket for oil drain plug? 2.3L - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 01-29-2006, 10:05 AM
scamp588 scamp588 is offline
scamp588 is starting off with a positive reputation.
Question What size wrench/socket for oil drain plug? 2.3L
Gettin' ready to change oil & filter on '06 Ranger w/2.3 Liter, and was wondering if someone could tell me what size wrench/socket I would need to remove oil drain plug? Thanks in advance for any help!!!
Old 01-29-2006, 10:34 AM
Noble Lumpkin Noble Lumpkin is offline
Noble Lumpkin is starting off with a positive reputation.
Same here but I want to know for a 2005 4.0L. I'm too old to climb under and check. Sucks to get old.
Old 01-29-2006, 12:29 PM
hotwheel_2000 hotwheel_2000 is offline
hotwheel_2000 is starting off with a positive reputation.
I belive my 96' is a 15mm.
Old 01-29-2006, 03:33 PM
el conquistador el conquistador is offline
el conquistador is starting off with a positive reputation.
Quote:
my dads 06 2.3 needed a 14 mm
Mid engine swap...need help please! Glaser67 Clutch, Transmission, Differential, Axle & Transfer Case 4 05-11-2016 09:51 PM
92 F250 2WD E4OD removal - bell housing bolts! F250F250F250 1987 - 1996 F150 & Larger F-Series Trucks 38 01-25-2016 04:41 AM
Aviator power steering leak shorod Explorer, Sport Trac, Mountaineer & Aviator 1 06-09-2011 10:30 PM
95 F150 Rear Bumper Bracket Removal marragtop 1987 - 1996 F150 & Larger F-Series Trucks 3 03-02-2011 09:12 PM
oil drain plug 93 F150 with 300 6 cylinder 06sd4x4 Ford Inline Six, 200, 250, 4.9L / 300 2 09-02-2009 10:03 PM
Tags
2003, 2007, 23, 96, change, drain, escape, f150, fits, ford, oil, plug, ranger, size, socket, wrench
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
