CCV Mod photos from kit off ebay.
01-28-2006, 04:51 PM
on
2001 PSD WITH CCV MOD COMPLETED. 14 PHOTOS TO FOLLOW.
START OF JOB.
01-28-2006, 04:52 PM
on
lOOK AT THE 7.3
how much did you have to pay for that? all it cost me was $10 for a length of 15' hose.
01-28-2006, 04:54 PM
on
REMOVED kWIK MOD AIR CLEANER AND NOW REMOVING THE CCV VENT. CUTTING THE TUB FROM VENT TO REMOVE, ITS EASIER THAT WAY.
01-28-2006, 04:55 PM
on
ALL AIR TUBES REMOVED.
01-28-2006, 04:56 PM
on
REMOVING THE CCV VENT FROM VALVE COVER.
you know you can put all of these in one post!
01-28-2006, 04:57 PM
on
CCV VENT WAS RUSTED SO I TOOK IT OFF SANDED AND PUT RUST BULLET ON. THEN I WILL PAINT WITH BLACK AS YOU WILL SEE.
01-28-2006, 04:58 PM
on
MARK 2 1/2 INCHES OFF HOSE AND CUT. THEN CLAMP TO ELBOW PROVIDED.
01-28-2006, 05:00 PM
on
I ROUTED HOSE OVER STEERING SHAFT AND THRU FRAME ON DRIVERS SIDE. MANY WAYS TO DO THIS I SUPPOSE.MAY CHANGE AT A LATER DATE.
01-28-2006, 05:01 PM
on
HOSE ROUTED OVER STEERING SHAFT AND READY FOR CCV VENT (PAINT WAS DRYING).
on
REMOVING OLD VENT TUBE.
01-28-2006, 05:03 PM
on
NEW VENT TUBE INSTALLED.
01-28-2006, 05:04 PM
on
CCV VENT PAINTED AND PUT BACK IN. MAKE SURE TO NOT LOOSE O RING UNDER VENT. I SILICONED MINE IN PLACE.
01-28-2006, 05:07 PM
on
NEW VENT AND AIR TUBS RE INSTALLED. THE BOLTS WERE ALITTLE TOUCHY BECAUSE OF THE ANGLE OF THE BRACKET. I NEEDED NEEDLE NOSE PLIERS TO PLACE WASHER AND NYLOCK NUT ON BOTTOM BOLT.NOTICE GREEN LINE REPLCED IN STOCK LOCATION, DONT KINK THIS LINE.
