1997 F150, 4x4 Cruise Control - Not Working
Looking for some help:
1997 F150, 5 speed manual trans, 4x4
Crusie control was working properly. I went to use it recently on a long trip and it did not work, no light on dash or anything. Thought it may be due to the recall, I had the recall completed, but went ahead and bought new presure switch that sits on master cylinder to be on safe side. Checked both fuses, under dash and under hood, all fuses are good.
I recently put a heater core in the truck, followed the directions provided by a memeber of this web site, they are excellent! I re-checked all of the connections that I could possibly think that may have had something to do with this problem, I see nothing. Especially on the passenger side.
A wiring diagram may help, or some good check points so that I can work backwards to pinpoint the issue, any advice would greatly appreciated.
Thanks in Advance
Scott
Thanks in Advance
Scott
Originally Posted by ATC Crazy
How long ago did you have the recall fix performed? Call up the shop and tell them whats happening. They might have a warranty on the work they did, or they might check it over and see if the problem is in what they did or another part of the wiring.
Thanks for your reply
bigred4601
1999 to 2016 Super Duty
10-08-2012 02:16 PM
DWTucker
09-12-2002 08:56 PM
