New Hampshire Chapter Join Chapter Leader: 7283-F250
10 mpg
Old 01-29-2006, 04:17 PM
frdtruc1's Avatar
frdtruc1
frdtruc1 is offline
10 mpg
Previously posted in another forum, but so many errors and typos, I thought I would repost here and try for a response from the locals.
Here is my dilema. Quite simply, I seem to be getting lousy gas mileage. After a 300 mi round trip to So Maine yesterday, I determined I am only getting 10 mpg.
This eng is a newer rebuilt 4.9, (done in 03) with less than 10,000 miles. It is in an 89 F150, sb. 5spd, 4wd. (Rear axle ratio is 3.55) 31x10.5x15 tires.
I don't drive this hard at all. Avg 65 mgh, all highway, Am I expecting too much or should I be getting better mileage here? Is there an easy way to pin this down? Plugs, wires etc. Any advice will be appreciated.
Old 01-29-2006, 06:46 PM
sglaine's Avatar
sglaine
sglaine is offline
Posting Legend
How about the air filter and fuel filter. When were they replaced last?
Old 01-29-2006, 08:01 PM
frdtruc1's Avatar
frdtruc1
frdtruc1 is offline
Its been almost 5,000 since I changed the air filter. I have never changed the fuel filter. I plan to change both as well as invest in new plugs and wires next week. It's been running fine, other than the lousy mileage. I've also checked for leaks and don't smell any oder of gas, but not ruling that out either.
Old 01-31-2006, 08:06 PM
matt h's Avatar
matt h
matt h is offline
10 mpg
hey frank,matt h here.was reading ur thread and it made me remember back when i had a 1980 gmc shortbed.i turned that thing into an offroad monster.early on before any real work,the first thing i did was put on some used 31's and almost instantly my mileage went down the tubes.you wouldnt think so cuz their really not that big,but tis true.also my speedo went off by 7mph.if possible experiment with smaller stock size tires and see if it gets better,curious to hear if tires r problem.looked up ur gallery pics,nice truck!good luck matt h
Old 02-01-2006, 03:48 PM
frdtruc1's Avatar
frdtruc1
frdtruc1 is offline
I just arrainged to drop it off at the local garage in town. He is very honest and reliable. I have him checking the codes for a problem sensor. This weekend the truck will get new wires/plugs/air filter for starters. Need them anyway. Will let you know Tuesday how I fared. I know I can't go on getting 10 mpg with the price of gas around here. Hopefully it not just tires. I am guessing its the Oxy. sensor. See if I'm right...Frank
Old 02-01-2006, 10:27 PM
LB3711's Avatar
LB3711
LB3711 is offline
find a spot that has a measured Mile and see how long it takes ad 60mph to do it. If it takes you a minute then the tires are ok. if not then your off. If it takes you less then a minute then your going faster if more than your going slower. Or just find someone else and have then go a set speed and go the same and then that will tell you if your off or not
Old 02-05-2006, 08:17 AM
matt h's Avatar
matt h
matt h is offline
damn ur good!lol matt h
Old 02-05-2006, 03:58 PM
LB3711's Avatar
LB3711
LB3711 is offline
I been doin this forum stuff since 01 and I know a decent amount and been playing with my ranger alot more lately
Old 02-20-2006, 08:36 PM
frdtruc1's Avatar
frdtruc1
frdtruc1 is offline
To Matt and others who responded re low gas mileage. I am changing the 02 sensor. This based on putting the engine on a scope. Too old of a truck to have comp codes read. Result, needs new 02 sensor. Everything else checks out. I did put smaller tires on last week and have not driven it to determine if mileage affected. Will probably check that later this week. Hard to believe just changing the 02 sensor is enough to make a diff. but I'll let you guys know. Will be a while but will respond.
Old 02-21-2006, 08:27 AM
sglaine's Avatar
sglaine
sglaine is offline
Posting Legend
You do have a very good point there.
Dustin44
32
02-13-2020 02:08 PM
bcoz22
Modular V10 (6.8l)
52
06-07-2011 06:25 PM
rwdfan
2004 - 2008 F150
11-07-2010 06:54 AM
lougil
1999 to 2016 Super Duty
17
01-18-2008 06:46 PM
FordtruckBoy13
Modular V10 (6.8l)
71
10-27-2006 01:39 PM
Quick Reply: 10 mpg
