97 ford ranger wont go into first or second gear - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 01-27-2006, 04:45 PM
bondo28 bondo28 is offline
bondo28 is starting off with a positive reputation.
I have a high mileage 97 ford ranger with the 5 speed manuel. It won't go into first or second gear. Goes into third, fourth, fifth, and reverse. i had to take off in 3rd to get home from a couple miles from my house. Thanks for any input you guys can give me.
Old 01-27-2006, 05:28 PM
john112deere's Avatar
john112deere john112deere is offline
john112deere is gaining momentum as a positive member of FTE.
Can you shift it into those gears if the engine is off?
What does it feel like when it won't go in?
My high-mileage '97 is tricky to get into first/second, too. I think it's a combination of a slave that works less than 100% and worn synchros. It goes in OK if the engine is off.
Old 01-27-2006, 05:37 PM
it actually shifter actually slides past where it should stop to be in first, like it's not grabbing the gear
Old 01-27-2006, 05:51 PM
el conquistador el conquistador is offline
el conquistador is starting off with a positive reputation.
it is a common problem with these trannies. blocking rings are another thing to suspect in addition to the above
Old 01-27-2006, 06:15 PM
I just talked to a guy that said his ranger did the same thing, and all he did was pull the shifter out and set it back in, and it fixed it at least temporarily. That did not work for me.
Old 01-27-2006, 11:24 PM
Quote:
were the washers and bushings intact when you pulled it out. they are know to go bad.
Old 01-27-2006, 11:54 PM
RangerPilot's Avatar
RangerPilot RangerPilot is offline
RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.
Yeah may be lookin' at a rebuild, new clutch, bearing, slave, synchros. Not bad, will definetly greatly increase the life of the tranny.
97 f150 wont shift properly memphis_made 1997 - 2003 F150 4 05-21-2015 06:17 AM
3 on the tree linkage problems. Haydenfreeman47 1967 - 1972 F-100 & Larger F-Series Trucks 5 04-03-2015 05:30 PM
97 Ford Ranger Transmission Problem Firebirds71 Ranger & B-Series 5 03-10-2015 03:24 AM
97 Ford Ranger 2.3L 5speed Issues 97RangerFTW Ranger & B-Series 8 02-20-2010 05:56 PM
Help! '97 Ranger 2.3 hesitating IronHorseDriver Ranger & B-Series 8 04-19-2008 07:58 AM
Tags
97, dont, ford, gear, ranger, wont, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
